Results 1 to 9 of 9
- Aug 2013
- 2
August 8th, 2013 08:07 AM #1Magkano po kaya ang aabutin kapag nagpachange-oil ako? And suggestions naman po saan maganda magpachange-oil. Newbie po ako sa ganitong bagay. Thanks in advance..
August 8th, 2013 09:33 AM #2
What's the model and mileage of your car? What area are you from? That can help others give you suggestions.
A servitek station is one place to start. There are also shops like Speedyfix, etc.
August 8th, 2013 09:39 AM #3
Buy your oil and oil filter from casa and make sure to also purchase a new crush washer for the drain plug. The crush washer is single-use part that should be replaced once removed.
Go to a Servitek station and just pay for labor. The Servitek on Congressional Ave. charges me just P150.
- Aug 2013
- 2
August 8th, 2013 10:37 AM #4My car is Toyota Camry model 2000.
My area is Dasmarinas Cavite.
any suggestion po saan magandang shop near my area? Thanks.
Any idea kung magkano po aabutin ko all in all? Thanks..
August 8th, 2013 11:01 AM #5
August 8th, 2013 11:32 AM #6
August 8th, 2013 12:25 PM #7
What's your mileage and when was the last time you had your transmission oil changed? Is the shifting still smooth?
August 8th, 2013 12:49 PM #8
Im confused.
TS. What job do you want done in your car?
An "engine" oil change?
Or a "transmission" oil change?
August 8th, 2013 06:50 PM #9
