Results 21 to 30 of 30
- Oct 2008
- 85
December 10th, 2010 01:18 AM #21in a way it is correct. once you put it in the engine, it gets contaminated. contaminated oil gets "spoiled". for storage purposes, it is adequate, however, once the car gets used again, kelangan na sya palitan.
it falls under severe driving, contrary to common sense.
too much fuel dilution, and the oil doesn't get the chance to reach operating temps (no chance to get rid of the fuel and/or other contaminants)
you'll have to drain and replace the oil sooner.
an alternative is to use it regularly for long drives. going out of town on weekends will help. masaya pa!
- Oct 2008
- 656
December 10th, 2010 01:58 AM #23
If you drive around in traffic a lot like we do here in Metro Manila, the time the engine is running at idle RPM becomes a factor. Leaving the engine at idle RPM for a significant amount of time has detrimental effects on oil life and by extension, added engine wear.
That's why it is not the best practice to just rely on traveled distance to decide on when to change the oil. The actual engine run-time is actually the reason why car manufacturers specify a "whichever comes first" clause.
December 10th, 2010 02:26 AM #24
December 12th, 2010 05:18 PM #25
just had my car oil changed.... using Honda's VTEC LEV SL5W40..... gumanda takbo... hehehhee!!! will use the 6mos or 10k w/c ever comes first.... will create a new thread SPARK PLUG naman hahahaha!! see guys there
December 12th, 2010 06:25 PM #26
eto idol oh, baka makatulong sa spark plug thread mu.
http://tsikot.yehey.com/forums/showthread.php?t=28969
December 14th, 2010 11:49 PM #27
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 17th, 2010 07:46 AM #28the "contamination", or removal of the dirt from the engine is normal. what you should be worried about is the absorbtion of water from the atmosphere. this holds true especially for cars that are hardly used. the oil will tend to become less viscous and will not perform as well once there is water contamination that has happened.
re: the duration, longer is ok as long as the oil can take it. replacing it too often is a waste of money. just make sure the level is always in check.
December 17th, 2010 10:57 AM #29
- Dec 2003
- 137
December 21st, 2010 12:52 PM #30If on a budget, it's better to use mineral oil and just change it frequently. No matter how good the additives in synthetic oils are, you're still stuck with contaminants floating around in it if you prolong your change intervals. Fresh oil is best.
Na lock ang Gcash ko, need verification pa and kasama sa list nila ang philsys ID paper, but when I...
National ID Law
