Results 1 to 10 of 30
November 12th, 2010 04:55 AM #1
Ano po ba dapat?
1) every 3mos
2) every 5,000 KM
3) which ever comes first between 1 and 2
4) others?
considering fully synthetic oil ang gamit.... TIA
November 12th, 2010 05:55 AM #2
anung kotse sir?
kung yung sa altis, dapat every 5k km. masyadong magastos pag-every 3months change oil. imho.
nakaka 6months ata ako before magchangeoil, i use RP oil that is good for mostly 7k kms, but im replacing it at 5k km mark.
and afaik, para sa city, every 5k km ata ang change oil filter and oil top up. pero ang change oil is at every 10k km. though im not sure
- Feb 2008
- 128
November 16th, 2010 08:19 PM #4naitanong ko yan sa service advisor..every 5k km daw pwede pms..kung synthetic oil gamit mo check up din after 5k km pero dadagdagan lang ulit ng synthetic oil, siguro konti lang tapos linisin din ang air filter yata..
November 17th, 2010 01:32 AM #5
November 17th, 2010 07:24 AM #6
November 17th, 2010 10:20 PM #7
November 17th, 2010 11:36 PM #8
dati once a year lang change oil ko. short trips lang kasi ako daily. so I reverted back
to ordinary oil para 2X a year. para di masyado mabigat you can opt for semi- synthetic na lang. pero if you have the budget go synthetic
- Feb 2010
- 336
November 17th, 2010 11:45 PM #9mine, i usually follow the 10kkm PMS altho pricey i'm using fully synth oil but change oil filter & top up every 5kkm...i'm a distance traveled PMS follower than time interval (no. of months) coz how can you know the trouble/s of you're rig if you only utilized it once in awhile...
but those using mineral oil, better to follow the 5kkm or earlier change oil for added protection and assurance bcoz of lower grade oil...HTH
November 18th, 2010 01:25 AM #10
so i'll go for the 6mos or 5k which ever comes first.....thanks!!!!
Thank you!
