Page 5 of 5 FirstFirst 12345
Results 41 to 45 of 45
    Jan 2011
    #41
    Quote Originally Posted by tonzi View Post
    sir wala pa bukas ko pa malalaman. pina tune ko kasi yung computer box ko. it cost me 5k. sana maayos na. thanks
    Cge sir.. Thanks! Goodluck!!
    Oct 2009
    #42
    Guys ok na po kotse ko..
    changed computer box: 8k
    changed sparkplugs and CTS (coolant temperature sensor): 1.4k
    labor :2.5k
    Mechanic: G6 banawe.
    masakit sa bulsa pero ok na din may sira na din kasi computer box ko kaya ok na din ganda ng takbo. btw sir richmond pa check mo yung CTS mo & spark plugs.. baka yun din yung culprit.
    thanks for helping guys.
    another problem I need latero for my mouldings problem.
    Jan 2011
    #43
    labor :2.5k
    Waaaaaahhh!! Ang mahal naman!!! how about ur main relay sir? Hindi mo na ba pinacheck? Observe mo sir then try to update us if the problem is really solved. Thanks!! Congrats ok na ang EG mo!
    Oct 2009
    #44
    Quote Originally Posted by r1chm0nd View Post
    wala talaga problema relay ko. sa sensor daw talaga. bali yung comp box nagpalit na lang din kasi ako. nag compare kasi ako sa comp box ng luma tska sa bagong comp box ang layo ng deperensya. mas maganda hatak ng sa bago.
    Nov 2003
    #45
    normally if ayaw mawala cel it's the main relay at fault. it's cheaper pa than the ecu so better na unahin yun.
CEL doesn't turn off, during COLD SEASON
