Results 1 to 9 of 9
December 16th, 2002 03:54 PM #1
It has been discussed in other threads that a periodic muffler wash is good for removing soot and carbon deposits from the exhaust pipe of diesel-fed vehicles. The warning was that this should not be performed on a diesel vehicle that has a catalytic converter, such as the new Isuzu Trooper. My question therefore is is it better to stick with diesel vehicles that don't have the cat. converter installed, or does the presence of the converter outweigh the disadvantage of not getting a regular muffler wash?
December 16th, 2002 07:41 PM #2
mikey::: the ONLY advantage that a cat has is that youre not polluting the air as much as non-cat equipped versions. Catalytic converters rob you of HP and are expensive since they contain exotic metals such as platinum.
The answer to your question is a very personal one. Do you care for the environment enough to stick with a cat? Here in the PIs i guess the majority would answer no........ unfortunately for our lungs :|
December 17th, 2002 12:25 AM #3
Nagtanong ako minsan sa Nodalos regarding catalytic converters for diesel engines. Di daw siya nakakabawas ng black smoke. It only removes toxic gasses. They sell it for 14k per unit. I hope this helps.
December 17th, 2002 09:15 AM #4
thanks for the ideas, guys. i guess pushing for cleaner diesel fuel and following proper engine maintenance would do more good for the environment than a cat in the Phils.
December 20th, 2002 02:26 PM #7
i agree mikey. Tignan mo gobyerno, they dont even mandate that cat-converters be standard equipment :D All they have to do is say so.
Tsikot Member Rank 4
- Jan 2003
- 2,979
February 5th, 2003 01:37 PM #8Hello! I'm a newbie here. Paano mo papalinis ang muffler mo pag may catalytic converter ka na installed???
February 5th, 2003 02:19 PM #9
badsekktor, ako honestly, di ko alam...in our case, wala pa naman kaming nama-muffler wash na may catalytic converter (panay PUJ kasi eh)...masama yata mabasa iyon eh kaya mukhang di pwede i-muffler wash...
meron nga akong nakita tungkol sa catalytic converters...di ko pa nababasa masyado:
http://auto.howstuffworks.com/question66.htm
http://auto.howstuffworks.com/question482.htm
http://auto.howstuffworks.com/framed.htm?parent=question482.htm&url=http://www.autosite.com/garage/subsys/catalyti.asp
My Ford SYNC just updated itself. Anyone here knows what was updated?
2023 Ford Everest Owners Thread
