Results 1 to 9 of 9
- Mar 2012
- 7
June 26th, 2012 01:04 AM #1Hi guys, anyone here experienced this problem in shaking?
Napansin ko lang kasi naginginig sya everytime na nakabukas ang AC at naka-drive/reverse and kambyo and I step on brake. Pag umaandar naman swabe lang.
While AC is off, normal 1k and idling pag bukas ng AC bumababa na sya up to 700 and shakes, medyo nakaka-irita. Pag Neutral naman walang shakes. So ang ginagawa ko, pag stop, nag Neutral na lng ako kasi nga it shakes habang nakaapak ako sa preno. Sometimes di na lang ako nag aircon.
Any tips mga sir, baka kaya sa DIY. If not ano kaya ang dapat kong ipaayos?
Car is Mitsubishi Lancer 1997 GLXI (Pizza), Matic
June 26th, 2012 09:37 AM #2
June 26th, 2012 10:35 AM #4
Im not quite sure with lancer pizza but for its bigger bother the galant this is a common problem of the galant 7g and 8g, culprit is a broken servo. The servo acts as a old school idle up device.
June 26th, 2012 11:05 AM #5
baka masyado mababa idling... have it adjusted... kung hindi na ma-adjust, may problema na yung servo siguro... a common problem with mitsubishi cars... yung lancer itlog namin nagpalit kami ng ganyan dati. plug and play part pero mahal, nasa 10k ata nun way back 1999.
- Dec 2010
- 87
July 1st, 2012 01:55 AM #6when braking lang???? try mo pa check yung check valve yung hose sa hydrovac ng brake. or may air leak ang hydrovac nyan.
- Jul 2012
- 9
July 28th, 2012 11:27 AM #8same problem with my car. kapag nakaapak sa break, lakas ng shake kaya lagi na lang akong naka neutral pag naka stop. Sabi daw engine support nmn ang prob. Tpos mahirap dw gwin kasi modified na yung current engine support ko. Btw, mitsubishi galant 95 matik. Engine changed from 6cyl to 4cyl..
July 28th, 2012 11:48 AM #9
Because pinoy mentality. Not surprising.
