Results 1 to 10 of 18
- Aug 2009
- 7
August 27th, 2009 08:54 AM #1hi guys. newbie ako sa forum. but from wat i saw. kakatuwa d2. dami ko nalalaman lalo. question lng. few months back ngpadukot ako. at first oki ulit takbo ng makina. lumakas ulit hatak. but a month ago kpag tntry kong bumirit parang sinisinok un makina ko. ayaw nya umakyat ng 4ooo rpm. ngpalit nko ng fuel filter dahil mejo luma na dn fuel filter ko (wat i tot the problem is). pro ganun pa dn. any suggestions? Tnx!
August 27th, 2009 09:23 AM #2
roadcrawler,
just like your thread, you leave a whole lot to guessing. what is your car make, model, year, mileage, fuel delivery type, ignition type. there is no time for guessing and hope you "fixed" the problem. guess and hope is not only costly, it is more expensive than going to an equipped shop with trained technicians.
jick
August 27th, 2009 09:30 AM #3
[SIZE="4"]REMINDER: do not post in SMS/TXT style format.
RULES: http://tsikot.yehey.com/forums/annou...php?f=123&a=19[/SIZE]
August 27th, 2009 09:35 AM #4
- Aug 2009
- 7
August 27th, 2009 09:40 AM #5mitsu. gli '95 efi. hindi ko nacheck un mileage eh. i think more than 500. nkasimota air intake ako. and kakalinis ko lang din eh. nung isang araw pinatry kong paadjust timing nung distributor. 1 day lang ok un takbo. kinabukasan ganun na ulit. hindi ko pa kse nababalik dun sa pinagpapagawan ko eh. im just hoping na may iba din nkexperience ng same problem and alam naging fix.
August 27th, 2009 09:54 AM #6
roadcrawler,
is your (MIL) malfunction indicator light or check engine light illumninated or blinking? did you refuel just before these symptoms started? what was the last thing done to your engine? aside from tampering with the then working ignition timing, did you have your oil changed?
jick
- Aug 2009
- 7
August 27th, 2009 10:05 AM #7last thing that was done was top overhaul. everytime nman na start ko engine nkilaw un check engine eh. pero kpag ngstart na hindi na sya iilaw. do you think e10 fuel has something to do with this? so far ang mga nagagawa plang. cleaning the servo. tpos adjust un distributor. chineck un spark plug medyo ok nman. tska kpag biglang rev maririnig mo un parang lunod.
August 27th, 2009 10:11 AM #8
could be that the E10 has an effect on it. One of my friend's liteace, which was just overhauled, really runs ugly on E10, but runs good on non-E10 fuel. try mo muna pag change ng fuel variant.
one more thing, were your spark plugs, fuel filter and fuel lines cleaned and replaced?
August 27th, 2009 10:11 AM #9
mejo nagtetext type ka na naman sir
me tunog po ba na para siyang sinasakal?
kasi dati yung glxi ng friend ko pag hinugot ang MAF para siyang sinasakal pero lam ko pag ganun iilaw ata yung check engine? not sure
yung sa sentra ko naman ganyan din ang akin naman nasisira na pala fuel pump so bale pag ginas ko siya hindi na pala nakakabigay ng masyadong fuel
August 27th, 2009 10:19 AM #10
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
