Results 1 to 10 of 26
September 25th, 2015 06:48 AM #1
Hello tsikoteers
May iconsult lang ako regarding sa nangyari saken kagabi.
On my way home from Lipa to Manila, nagkatrouble si Avanza AT. Pagkaexit ko ng Tambo, bigla na lang umilaw si "check engine oil" then sabi ko na baka maka abot pa ng sto tomas kasi maraming talyer dun.
During the travel, may ingay pag inaapakan ko ung silinyador pero pag di naman, walang ingay. Hanggang sa umilaw na ung 3 warning lights sa dashboard (check batt, engine oil, etc.) Nung matabi ko, ayaw ng magstart. Pag ka click, wala ng redondo. Malakas naman battery. Kakapalit ko lang last year.
Ano kayang nangyari and ano magiging solusyon.
Car is *74k odo. Last change oil and maintenance *67k.
Thanks in advance.
September 25th, 2015 06:52 AM #2
Last oil change was mineral oil? When was the last oil change? 2 yrs ago?
- Jun 2005
- 3,774
September 25th, 2015 07:49 AM #3yari. dapat si mo na tinakbo. mukhang overhaul na katapat nyan bro.
probably due to sludge or natuyuan ka ng langis due to leak. either way, malaking gastos yan
September 25th, 2015 08:04 AM #4
Dapat po tinabi nyo na sir nun umilaw na yun oil indicator sir. I agree with sir sirkosero malamang general overhaul na po yan dahil tumigil na yun engine nyo while running. Pabuksan nyo po para malaman extent nang damage.
- Oct 2013
- 2,537
September 25th, 2015 08:34 AM #5you violated the basic driving rule of "NEVER drive on RED!" meaning stop driving as soon as you see a RED warning light on the instrument cluster... the engineers placed colors on that thing for a REASON, and RED means STOP!
since di ko naman nakikita tsikot mo, palagay ko engine seizure/lock up na yan due to poor lubrication as indicated by the low engine oil warning light that you mentioned...
September 25th, 2015 09:14 AM #6
So hindi pwedeng gamiting measurement ang oil dipstick? Kasi nasa right level naman sia.
Ang last na change oil was march 2015 and fully synthetic na ang gamit.
Lesson learned nga tong nangyaring ito. I was hoping na aabot hanggang sto tomas dahil nakalabas na ko ng star toll.
September 25th, 2015 09:35 AM #7
You won't really know the extent of internal damage of your engine until you get it opened sir. Even if the dipstick oil level is good the sludge inside due to long change oil intervals sticks to your engines internal parts and the little holes where oil should pass has clogged up slowly killing it. Best is to maintain a regular 5k kms or 4months change oil routine to prevent sludge. Kahit mineral basta regular and change oil lang.
- 54,215
September 25th, 2015 09:46 AM #8- - - - - - - - - - - - - - - - - - - - - -
... sounds expensive...
engine seizure due to loss of lubrication?
only in opening up the engine will you know just how expensive..
if car is still under warranty, i think you should have toyota do the opening.. baka puede pang i-pasok sa warranty or insurance..Last edited by dr. d; September 25th, 2015 at 09:48 AM.
- Oct 2013
- 2,537
September 25th, 2015 10:48 AM #9
- Jun 2005
- 3,774
September 25th, 2015 11:32 AM #10may similar threas dito a few weeks back regarding an avanza that had sludge issue.
2nd case na ito sa thread for an avanza in less than a month
Roadstar is reliable.
Finding the Best Tire for You
