Results 1 to 3 of 3
June 1st, 2008 03:54 AM #1
Anu ba mas maganda pagkuha ng Fuel consumption technique.1) mag pa full tank at gamitin, tingnan ang odo meter,mag full tank ulit at compute the diference, then devide sa tinakbo.2) mag refill ng fuel full, reset ang odo meter counter sa bandang ibaba. mag pa full tank ulit then compute...Anu ba ang iba pang technique..........pls share
June 1st, 2008 05:42 AM #2
Ethier one will do. Just do that over a period of time of doing it, each time you fill up the gas tank and calculate the proximity. When your doing this... remember, load weight can increase fuel consumption so dont pick up hitchiker when doing this science of yours. Good luck.
- Sep 2004
- 132
June 1st, 2008 05:03 PM #3ok naman pareho yan. share ko na rin style ko since you ask
nagre-reset ako ng odo once my fuel gauge needle is at the center mark. yun ang reference ko. then karga ng gas. bahala ka na kung magkanu. ako usually 500 or 1000 pesos. tandaan mo lang kung ilang liters.
pag bumalik na sa center mark yung needle, take note of the reading. divide by the liters na kinarga mo. reset na naman ako.
kahit hindi muna ako mag karga immediately ok lang. basta naka reset nko at my reference mark. importante lang naman my reference ka an dun ka palagi mag reset. average after a few times, yun ang consumption ko.
madali ko ma monitor consumption ko sa pure city or pure highway driving.
Dati kasi, Sojitz Corp ang distributor ng Geely locally, ngayon Geely Motor Philippines Corp....
BYD Philippines
