Page 1 of 2 12 LastLast
Results 1 to 10 of 66
    Jan 2009
    While trying to decipher if it matters if I use 5W30 over 15w40 for my next engine oil change I got this in http://www.carbibles.com/engineoil_bible.html.
    Toyota sludge problems.
    For their part, Toyota have the dubious honour of having the most complaints about sludge buildup in their engines - 3,400 at the last count. At the time of writing there is a class action suit going on against them. Details can be found at www.oilgelsettlement.com
    Toyota seems to have lost the case. Since the cars cover older models (pre-2007) then it would be of interest only to owners of older Toyotas and Lexus.
    Kung 2007 or mas luma toyota mo it would be a good idea to be diligent in changing your engine oil. Unless interested kang makita ang "black death" or sludge.
    Aug 2004
    You have to be diligent in changing oil on the Altis... as the engine is one of those included in the complaints.
    I've seen one here which has died the black death. Pero poor maintenance yung cause (missed oil change). As long as you follow the short local oil change schedules (5000 kilometers), there should be no trouble.
    From reports from the US, even using synthetic oil will not protect the engine if you go to a long-change interval... so it's advisable to stick to the short interval, whatever oil you're using.
    How about the 1NZ-FE engine (Vios/Yaris) affected din ba?
    I use 5w-30 Royal Purple synthetic oil on our altis (1zzfe) and at 9000kms there's a visible sludge at the oil filler.
    I'm back again to the 5 kms change oil.
    Aug 2005
    I am using RP din sa ZZ namin. Migs suggested to use Diesel oil for about 500 to 2000Km before the next change oil to clean the possible sludge. Diesel oils has the most detergents. Might try this. currently about 3,700 km from the last change oil.
    Aug 2004
    The Vios engine... unknown... personally... unless the VCP (vios club philippines) can confirm whether this happens with them...
    Again... it's not just the oil that determines the change interval... it's the engine itself. If the engine has a recommended 5,000 kilometer interval on mineral oil, that doesn't mean that switching to synthetic will double that. At the very least, you will have to change your filter at 5,000 and check for oil contamination before deciding to keep your oil for another 5k.
    *[/b]s_quilicot[/b]: ouch. Engine still runs okay, I hope?
    May 2005
    What if 5,000 kms can't be reached very quickly? In other words, what is the M.O. for low mileage cars using Toyota's mineral oil? Is it every 3 months (regardless of kms reading)?
    Mar 2003
    They are a bit quiet and assuring me that there is nothing to pay... That's the reason I want a documented report on their end... Requested for computerized report and letter head of Toyota... Don't like verbal or just hand written on scratch paper... Wait and see muna ako...
    Just doing my own research for probable causes
    Jun 2005
    id ask them to replace the car under warranty. or at the very least replace the engine. dont bother yourself with repairing the engine.
    if they dont want to replace the engine, escalate to toyota philippines. not sure if jing delgado is still there but you can escalate to her office to get fast resolution.
    Quote Originally Posted by sirkosero View Post
    Toyota has to diagnose the engine muna, then try to repair it. if unrepairable, then they have to replace the engine na siguro.
    cta2, ano service record mo with toyota? on time naman parati yung change oil mo? also, after opening the valve cover, what did they find out? you have to ask them na agad. kasi may makikita na agad sila pag bukas ng valve cover. i suggest go to toyota and pasok ka sa work shop nila to see what is happening. you have to visit the casa everyday if possible.
Black Sludge and Toyota/Lexus
