Results 1 to 7 of 7
April 4th, 2013 01:26 AM #1
Hi car gurus my ask lang ako kung my na experience na kayo na ganto.. Yung honda city type Z year 2000 A/T ko biglang humina aircon after ko ibyahe ng malapit lang and napansin ko my kakaibang amoy from aircon and humina buga nung hangin so i parked my car and na notice ko pag angat ko ng hood parang my nag squeaking sound and amoy sunog na goma so i turned off my car and examine the belts and engine wala naman ako napansin kakaiba so i start ko ulit yung car and aircon and nawala yung tunog and lumakas na din yung buga ng aircon sa tingin niyo need na replace yung belts nya? parang my nabasa ako slipping belts daw tawag dito kung yung belts nga yung amoy sunog na goma i need inputs po sa mga nakaranas ng ganto Thanks a lot fellow tsikoters looking forward sa mga comments nyo.
April 4th, 2013 01:36 AM #2
Pacheck mo na mga belts mo and their pulleys, puwedeng maluwag lang ang belt or may malapit nang ma stuck up na pulley.
April 4th, 2013 10:28 AM #3
happened to me.
culprit was a failing compressor bearing.
tumitigas kaya may pressure pagikot resulting in burning rubber which is yung fan belt.
April 5th, 2013 10:32 AM #4
Any other inputs guys? nung ginamit ko ulit car ko and pag bukas ko aircon nanginginig yung compressor with burnt rubber smell tapos up and down yung rev nung kotse kaya pinatay ko na lang ulit try ko dalin ky frigid zone.. ayaw ko ky mang mario dami na negative feedback hehe
BANNED BANNED BANNED
- Jul 2003
- 2,267
April 5th, 2013 10:39 AM #5
April 10th, 2013 03:35 AM #6
Naayos na and ang culprit lang is yung pressure switch wala masyadong contact sa drier. buti na lang nag pa 2nd opinion ako ang sabi ba naman sakin sa unang shop na pinuntahan ko need daw cleaning at barado na daw yung aircon ko sinisingil ako 3200 for cleaning kasama na daw materials na papalitan hindi ako naniwala kaya nag pa 2nd opinion ako. Dun sa 2nd shop na pinuntahan ko my electric test siyang ginawa and nirektahan niya lang yung Pressure switch and voila gumana na ng maayos yung compressor. inabutan ko na lang 150 yung gumawa kesa daw papalit daw ako ng drier at switch gagastos pa ako kaya ginawan na lang paraan at tatagal naman daw yun.
April 10th, 2013 03:57 AM #7
Parang maintenance ng Master Garage ito? Sent from my 2107113SG using Tsikot Forums mobile app
