Results 1 to 7 of 7
    Pacheck mo na mga belts mo and their pulleys, puwedeng maluwag lang ang belt or may malapit nang ma stuck up na pulley.
    happened to me.
    culprit was a failing compressor bearing.
    tumitigas kaya may pressure pagikot resulting in burning rubber which is yung fan belt.
    Aug 2010
    Any other inputs guys? nung ginamit ko ulit car ko and pag bukas ko aircon nanginginig yung compressor with burnt rubber smell tapos up and down yung rev nung kotse kaya pinatay ko na lang ulit try ko dalin ky frigid zone.. ayaw ko ky mang mario dami na negative feedback hehe
    Jul 2003
    Quote Originally Posted by gr3nd3l View Post
    it is quite obvious now that the problem is connected with the aircon i.e. compressor.
    have it checked. get back to us if the problem is not the compressor.
    Aug 2010
    Naayos na and ang culprit lang is yung pressure switch wala masyadong contact sa drier. buti na lang nag pa 2nd opinion ako ang sabi ba naman sakin sa unang shop na pinuntahan ko need daw cleaning at barado na daw yung aircon ko sinisingil ako 3200 for cleaning kasama na daw materials na papalitan hindi ako naniwala kaya nag pa 2nd opinion ako. Dun sa 2nd shop na pinuntahan ko my electric test siyang ginawa and nirektahan niya lang yung Pressure switch and voila gumana na ng maayos yung compressor. inabutan ko na lang 150 yung gumawa kesa daw papalit daw ako ng drier at switch gagastos pa ako kaya ginawan na lang paraan at tatagal naman daw yun.
    Puwedeng malaman yung name ng first shop para maiwasan namin? And name naman ng second shop para kung sakaling may papagawa kami. Thanks.
Burnt rubber smell sa engine bay and humina aircon Help pls
