Results 1 to 10 of 70
Threaded View
- Apr 2010
- 71
August 12th, 2013 01:44 PM #1Hello tsikoteers, just wanna know if the starter can be a major reason of cold start problem? Sorry if you find this a non-sense question, the reason I asked this because our car is only experiencing hard starting at first start, but when the car finally starts, wala na pong problema sa maghapon even if you on and off the engine, one click na lang.
- Carb was already properly overhauled in kamuning and replaced complete set of carb kit not just the o-rings
- OEM magnetic fuel valve was also replaced
- NGK plugs were just replaced last May
- Fuel filter is also new.
Is there any other things to consider to finally solve a cold start issue?
Ride is honda 92 / PH12 engine. Any response will be highly appreciated. TIA
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
