Quote Originally Posted by innova2013 View Post
same break-in procedure din ba sa mga bagong overhaul ng makina?
After starting I usually run it straight 15-30 min if there is no sign of leaks. Then shut it down double ck fluid levels then run engine at idle for 1 hr after that increase rpm to 750-1000 rpm for 4-6 hrs I call it standing break in. If dyno is available ill strap it on the dyno and of we go. If not I'll drive it for 150klm that's the end of it give it to the driver so they can burn fuel..
