Results 1 to 3 of 3
    Jul 2010
    Guys Has anyone here done any modification on their crankcase ventilation system primarily diesel engines? Like slash cut exhaust pcv
    Im planning on doing this but im not quiet so sure where can i buy a check valve..
    Your opinions and suggestions are welcome.
    Feb 2009
    Quote Originally Posted by TheGreenThing View Post
    the gas flow of PCV systems start from filtered ambient air, goes into the crankcase, mixes the ambient air with blowby gases and fumes of engine oil vapors inside the crankcase, pulled into the intake system and the blowby gases diluted with air and oil fumes are introduced into the combustion chambers to be oxidized. the fumes do not go straight to the exhaust pipes
    Oct 2004
    Venting blow-by gases via the exhaust pipe is exactly the same as venting the blow-by gases directly into atmosphere.
    Just add oil catch bin to your stock PCV routing.
Blow-by gasses
