Results 1 to 12 of 12
    Jan 2009
    totoo ba ung kapag bigla kang narelease ng silinyador ay nahigop ang exhaust?
    di namn cguro totoo yun di ba?
    false. The exhaust gas velocity simply slows down. It never reverses in flow.
    May 2007
    What Ghosthunter mentioned is the truth. Otherwise, a car will be the most expensive vacuum cleaner anyone ever bought! hehehe
    Jun 2006
    Agree. Your exhaust will have pressure. The combusted air from your engine is going out. It will keep the water from entering your engine.
    If your engine is not running and you fill your tail pipe with water, the water will blow out when you start the engine.
    Oct 2008
    hindi po totoo may nahihigop sa exhaust.. kya may water kasi normal lang po yan dahil humid po sa loob ng exhaust natin sir
    Aug 2004
    Quote Originally Posted by marcasjr View Post
    No... I agree with Ghost et al
    If you're worried about the water droplets coming out of the tailpipe, it's normal when the pipe is still cold. Exhaust gas consists of water vapor, carbon dioxide, carbon monoxide, unburnt fuel, carbon particles, etc. What you see is the water vapor condensing into liquid water .....
    Safe driving!
  7. #7
    kaya useless ang hard revving on flood forging... be wary more of your intake than our exhaust...
    Aug 2005
    Quote Originally Posted by alwayz_yummy View Post
    Not in all cases sir. Pag idle/near idle rpm ang makina at fully submerged ang tailpipe mo, may chance na mag stall ang makina and malabo mo na ma start uli.
    Jan 2008
    not a chance.. exhaust will always blow out what ever comes in.. but in flood, when the tail pipe is submerged, you need to keep the engine above idle to prevent it from stalling.. when the tail pipe is submerged and you let the engine idle in flood, the water volume will be enough to block the tail pipe stalling the engine.. once the water goes inside the tail pipe, you will have a hard time cranking the engine again since your exhaust is blocked
    a most powerful and expensive vacuum cleaner!
    most of the time, it's the tailpipe doing the the first dip since it is lower than the intake. probably part of the design to save the engine.?.
exhaust sucks water?
