Results 1 to 13 of 13
    Apr 2005
    tsikoteers,
    im using regular ngk plugs and castrol 15w-40 motor oil... if i change to iridium plugs and 10w-30 motor oil, would it improve my fuel consumption? i was thinking kasi maybe 5w-40 would be a bit to thin for a 10 year old car, or is it?
    AFAIK motor oils contribute to better fuel mileage, do spark plugs have the same effect also? befor kasi i used bosch super four & to me it felt kinda "malakas sa gas" or is it just me?
    thanks!
    Jan 2004
    sir, why use lower viscosity oils on older cars? i read somewhere it is not recommended but instead you should use 20W-50 for your engine. this provides better protection since your internals were well broken-in unlike to those newer models. anyways, haven't tried the spark plugs with iridium tips, its really expensive. they say, there are slight performance gain using iridiums, but then if you are trying to conserve then why buy components that are expensive enough and functions just the same?
    if you want to conserve fuel then, try to change your driving habits / style.
    we have a thread concerning fuel consumption, just feel free to search the website.
    cheers
    stock components are made to maximize fuel economy.iridiums "daw" produces better performance....i doubt you'll ever feel it if you dont go racing.
    and i had bad experiences with iridiums used by galants....
    about the oil...use regular mineral oil lang lalo na sa older car.
    Jun 2004
    From what I read Iridium Plugs can only improve mileage by about 1% at the most, this assumes that the engine is in tip top condition. Stock plugs would be best for a stock engine.
    Aug 2004
    There are quite a number of engines that actually don't see any practical benefit from a change of plugs. If you're already using a certain style or brand, getting the top end version in platinum may help, but if you get a multi-point or fancy plug, your engine may or may not like it.
    As for oil, 0 weight and 5 weight are not usually recommended for old engines because your clearances may already be too large and may let oil out. If you do choose to use these, be very careful. Trust me, this is from experience.
    10w is a good compromise. I disagree with going to 20w, because it may make your engine feel a bit sluggish and un-eager to rev. Just check your oil consumption to make sure that your car isn't letting it past your piston rings. And since it's an old car and you should be following the 5000km interval religiously, it's better to use mineral oil, as you won't save any money using synthetic.
    If you plan to go racing, it might be worth it to use synthetic, but from an economy point of view, no. I use sythetic on my old cars only because I run my engines very hard. :lol:
    Apr 2005
    yeah, i heard it may be unwise to use a thin viscosity on older cars that's why i went 15w-40 and so far i haven't noticed any leaks or seepage. and yes, i do find the 20w a bit sluggish so i was just wondering if it would be pushing my luck if i went 10w.
    oh well, having read your comments, i may just quit while i'm ahead and stick with 15w. as to the plugs, i may just go platinum.
    thanks guys!
    Apr 2005
    incidentally, i was reffering to my nissan presea, not the galant (still an old car nonetheless). forgot to mention the car, hehe.
    thanks again...
    Jan 2003
    so useless pala mag upgrade ng plugs kng stock engine?
    Aug 2004
    At most, 1-2 hp lang ang makukuha mo, pero gamble lang siya. Some aftermarket plugs, kahit platinum o iridium, nag-ca-cause ng hp loss dahil either masyadong mahaba ang head o marami ang contact points (diffused yung spark). Best kung may mahanap kang dyno results para sa engine mo mismo at yung plugs para malaman mo yung effects.
    Jul 2005
    Quote Originally Posted by niky
    Yap tried the denso iridium for crv 1st gen. I got 6.3 from city driving. and for long trip highway the lastest I got is 9.1km/lt...the previous trip running at almost 120 to 160 kms from Manila to la union in just around 3hrs 40mins just got only 7.6kms/lt only..
    Jul 2005
    Yap tried the denso iridium for crv 1st gen. and using synthetic Oil and high tension wire. I got 6.3 from city driving. and for long trip highway the lastest I got is 9.1km/lt...the previous trip running at almost 120 to 160 kms from Manila to la union in just around 3hrs 40mins just got only 7.6kms/lt only..
    tried iridiums....kakagok kaghok sasakyan ko...went back to stock....never had any problems...
    Another tip.. if you really want to know how much you are consuming fuel..
    Try starting to do a record.. list how much liters you purchased and the distance travelled then do the math..
    km/L = total distance travelled divided by liters consumed..
    This way you will know if you are reall y saving on your gas bills..
    Try it.. We do!
    Hope that helps!
    kiper
better fuel consumption
