Results 1 to 10 of 13
- Feb 2017
- 210
September 7th, 2018 03:38 PM #1Nag spray ako ng water sa rib side ng belt hindi huminto ang squeak. It is very hard to determine saang bearing nang gagaling ung noise, is there anyway na malaman ko which one ung squeaking? And then pano ko malaman ung bearing na bibilin ko?
- Nov 2009
- 3,484
September 7th, 2018 04:45 PM #2
If you are done checking the drive belts for cracks, you may remove one-by-one the drive belts to isolate the accessories (PS pump, AC compressor, alternator, WPump). Once you identified the bearing, check the part number printed on the cover then ask the bearing store for replacement. If water pump is the culprit, replace the assembly as the bearing is pressed on watertight seal.
- 52,701
September 8th, 2018 09:47 AM #5
I think OP should just bring his car to a mechanic to avoid making a mistake, if he can't find the simple squeaking sound I don't think he'll be able to do thr steps posted of removing belts and everything.
- Nov 2009
- 3,484
September 8th, 2018 10:14 AM #6
September 8th, 2018 10:16 AM #7
- Jan 2008
- 4,726
September 8th, 2018 10:31 AM #8
- Feb 2017
- 210
September 8th, 2018 10:47 PM #9Pwede b stethoscope ng doctor un lng meron aq
Sent from my SM-G532G using Tapatalk
- Jan 2018
- 844
September 8th, 2018 11:03 PM #10
