same with t2erns ang troubleshoot jan....pwedeng pudpod na yung end ng shaft that is connected sa oil pump...tingin ko buong assembly na yun kapag pinalitan i.e. distributor (w/ cap) and the shaft. start with the easiest first...
1. try changing the contact points and condenser with the right gap (0.020 in)
2. change the high tension wires baka naghahanap ng ibang ruta yung kuryente dahil cracked na rin.
3. try changing the cap
4. then change the whole distributor assy kung ayaw talaga
