Results 121 to 130 of 136
March 20th, 2012 10:07 AM #121
March 20th, 2012 10:26 AM #122
^dumako ka sa remote bypass filtration thread brader. andun ang sagot.
March 20th, 2012 10:26 AM #123
it also took a long time for smokers to get lung cancer... and drinkers to lose their liver...
if you're using something not so good, why continue? "culture"
March 20th, 2012 10:29 AM #124
^di pako nagquits sa smoke....hehehe. di sya culture. addiction. hehe
March 20th, 2012 11:48 AM #125
Well if you want about 4 times less filtering capability then it's a filter you want to use. There efficiency is terrible. They are on the very low scale barely 95% efficient at 40 microns when most good filters do that at 25 microns. So basically they miss a lot of particles and allow them to circulate through your oil.
Switch to a good filter and double your oils life.
- Jan 2008
- 4,726
March 20th, 2012 11:53 AM #126well then the problem is the supply... almost all auto shops carry VIC filters... other gas service station like shell now use PUROLATOR (is this good?) i just don't know if these are original parts... another worry is fake parts...
March 20th, 2012 12:00 PM #127
March 20th, 2012 12:02 PM #128
Toyota's OEM synthetic is 5W40. It's thinner when cold so it circulates agad.
March 21st, 2012 02:21 AM #129
minimum ideal temp for normal flow for oils is about 27 degrees Celsius... the problem begins when engine is hot and ambient temperature is also hot.. like here in the Philippines...
for gasoline engines, there's little time to wait for engine temp to rise because its SPARK combustion
In diesels it will take time to heat up engine due to compression combustion(especially old school diesels)
February 4th, 2013 09:49 PM #130
nag pa change oil ako and used hks 10w-38 fully synthetic....so far tahimik at maganda response...kaso vic yung filter ko....
galing pala ako sa castrol gtx na nilagay nung shop na nagpaingay at nagpabigat sa takbo ng auto ko, anyway, happy na ngayon, sana tuloy tuloy
If Mitsu prices this above 1.4M then buyers will flock to either the Corolla Cross hybrid, the...
Mitsubishi Xforce
