Results 101 to 110 of 136
- Feb 2003
- 1,038
March 18th, 2012 09:29 PM #101*miko....Agree agree ako sa post mo.
Thanks nga pala sa Zic oils and Baldwin filters...If you could find any oil test on ZIC UP and ZIC A pls. do share it.
March 18th, 2012 10:15 PM #103
Don't worry sir jiggs,, nagtatabi na ako mga used oil hehehe... tapos papa analyze ko sa Monarc...
UUnahin ko yan sa Petron trekker!! tpos Susunod ko si castrol,, haha...
Lakas kasi nang marketing nila eh,, tignan ko kung tunay nga na maganda oils nila...
sir jiggs, pag nag change oil ka, patabi at patago naman used oil mo ng ZIC UP at ZIC A,, pa analysis koh...
March 18th, 2012 10:47 PM #104
- Aug 2010
- 82
March 18th, 2012 11:42 PM #105i use petron trekker 15w-40 diesel oil on my pikup even on my gas fed car, ok sya kahit sa gasoline engine gamitin, kagandahan ng trekker di sya nag bi build ng sludge, runs smoother and mura lang sya 180 petot lang per liter.
March 19th, 2012 08:05 AM #106
Marami choices other than the BIg three companies... try to explore other lubricants that are way much better than them, additional 50 to 100 pesos per liter pero malayo difference in quality and performance...
Cost cutting on lubricants is never a way to save money... you're just saving up for a bigger expense later on.
- Aug 2010
- 82
March 19th, 2012 09:31 AM #107careful lang sa mga brand ng oil sir marami dyan repack lang ginagawa nila, gamit na lang kayo sa mga tried and tested, baka po mag ka sludge engine nyo, sa mga na try ko na mineral oil caltex and petron ang pina ka ok, sa synthetic mobil, royal purple and motul, stay
away from castrol.
March 19th, 2012 09:38 AM #108
i use valvoline semi-synths. so far so good naman. i prefer mobil 1 actually but it's not available everywhere
March 19th, 2012 09:56 AM #109
for my latest change oil this month i used Repsol Inyeccion for one of my diesel car. So far so good. i also use Top1, Motul, Mobil, Castrol(only Magnatec and Edge) and Royal Purple.
March 19th, 2012 11:43 AM #110
high idle RPM at engine start
