Results 1 to 17 of 17
    dapat kasi kung hindi ginagamit ang sasakyan ng matagal e pinapaandar mo kahit 5 minutes lang every week. o kaya kung walang tao sa bahay na magpapa-andar e alisin mo yung battery at ipatong sa kahoy na tuyo (huwag sa semento, madidischarge at masisira ang plates).
    yung redondo nya mabilis ba o yung parang naghihingalo? kung fully charge ang battery pwedeng 2 ang cause - loose connection sa battery, starter or ground, saka worn starter bushings.
    This is a myth. Our generator bat and backup bat is sitting on the floor for years without probs. We replace it every 3yrs no matter what the condition. I've also seen bat shops storing batteries out from the box on the floor. We have rectifier stations with batteries on the floor, no probs whatsoever. Bat discharge is more attributed to temp, the cooler the better.
    If you will not use the car, simply remove negative side of the bat, no need to remove the bat from the car.
    Again, negative side not the positive. Removing the positive makes it riskier for short ckt because the car chasis having the largest area is negative potential.
    Jul 2011
    sad to say medyo madaming reason kung bakit dumating sa ganitong sitwasyon yung van ko.. anyways, gusto ko na lang ulit mapaandar at ng madispatya na ;-)
    redondo nya yung parang naghihingalo
    secured naman ang koneksyon ng baterya
    Jan 2008
    Quote Originally Posted by gtamp View Post
    kung redondo nya eh parang nag hihingalo eh malamang may problema yung connection mo from battery to starter.. or yung starter mismo needs overhauling (replace bushings), or yung battery mo mismo hindi kaya yung starter.. change battery ka sa mas malakas (motolite ulit)
    May 2009
    gtamp,
    worn out starter carbon brush ang suspect ko jan sa van mo....malakas sa konsumo ng kuryente ang pudpod na carbon brush. assuming in good condition ang fuel system at engine mechanicals.
    as per my experience, nung nanghiram ako ng bagong battery mabagal ang cranking at parang ayaw tumuloy, nauutal sa cranking, etc at ayun i concluded na starter ang problema. since diyer ako, ako na rin nagpalit ng carbon brush. 4 pcs brush usually ang mga starter. fyi
    to give you approximate costs:
    1. Servicing - P500
    2. Carbon brush - P120-150
    mas mahal pa yung servicing kesa sa part.
    May 2009
    wag mo pala sa sanayin sa "kadyot starts"....di malayong clutch parts naman ang susunod na masira kung ganyan parati.
    Jul 2011
    thanks po sa lahat ng mga reply/comment/suggestion...very much appreciated po..
    meron akong nabasa sa isa mga thread dito na checkin ang fuel filter lalot natetengga ng matagal baka daw kase nagclog o kaya nagkatubig...luckily nagstart sya after 2x nagdrain at airbleed ng fuel filter...
    as of today napapaandar na sya ng hindi itinutulak pero hindi na tulad ng dati na 1-click lang..
    pero atleast nagi-start na ;-) thanks uli sa lahat
asking for other opinion coz my van wont start
