Hi guys. I have not driven my lancer 91 efi for 3 days now. Whenever the engine is running idle or driving, the rpm just fluctuates nonstop like crazy ranging from 1800-2200 rpm. I suspect it to be the idle control motor (servo motor). Whenever i turn the ignition key (engine still off) i can here a mild whirring or grinding sound coming from the servo motor that does not stop. Car's drivability is crazy. also check engine light is on. How can i pinpoint that this is the cause? Any diagnostic test i can do to verify this? Motor seems to receive current, because whirring noise disappears when wiring is disconnected from it. If the motor is the problem, can it be repaired? Iead from the forum that a brand new servo motor is not cheap. Please help!
