Results 1 to 3 of 3
February 4th, 2008 08:24 AM #1
I've observed that everytime I press the gas pedal, this certain whistling noise comes in. I've brought this problem up to a some mechanics and they said it's normal for my car (Civic 96) to sound this way. Some said it's the tappets (tama ba spelling?) and some says it's the the bearing (tensionare / tensioner ek ek). Saan ko po ba pwedeng dalin to para malaman yung totoo? Di ko lam kung gagawan lang ako ng pera nung mga yun. I've heard some vti and lxi engines and wala naman nito so I think it's not normal. Who would you recommend?
PS. Walang aircon po pag tinetesting ko. Sir speedyfix sana mabasa mo to. Kung mabasa mo man. magkano pagawa and parts. TIA
- Nov 2006
- 299
February 4th, 2008 02:35 PM #2try to check first for vacuum leak,like intake manifold gasket leak.it is most noticeable during high rpm. spray some injector cleaner in that area to find that annoying noise.the cleaner will create rough idle or sometimes the engine dies when it gets into the leak,but dont worry it wont hurt anything or if this is not the cause try to spray water to the belt and tensioner.
Tsikot Member Rank 5
- Nov 2003
- 3,849
February 10th, 2008 04:10 PM #3you will have to bring it over to see. mahirap magsabi kung di pa namin nakikita kung saan galing yung problem
Daming issue ng SU7:grin:
Xiaomi E-Car
