Results 1 to 5 of 5
    Need help! My old 93 Corolla Gli has problems with its RPM. Minsan it goes 1500 rpm on Normal Operating Temp then goes back to 1000. Then minsan bumababa ng 800 rpm at may "palag". Panu ko susulusyunan ito? Anu papa-ayos ko?
    Computer box?
    Aug 2007
    Sabi sa akin before...baka daw:
    1. Air sensors
    2. Reset the computer
    3. Filters need replacement
    try mo na lang.
    Dec 2007
    sir, if your engine is EFI, theres a chance that your IACV "Idle Air Control Valve" or the TPS "Throttle Position Sensor" is worn out or clogged (the IACV) or needs to be adjusted (the TPS). also check for Vacuum leaks as well.
    aite, peace.
    Thanks Guys! This is such a big help! Hope to get it fixed soon. God Bless!!!
Irratic RPM
