any performance benefits to having less fuel in the tank (due to reduced weight, and which would probably be not-too-significant anyway) will be offset by the inconvenience of having to fill up more often hehe :D at least for me
not to mention... 55 liters of gas (full tank) is only 55 kilos at most (but gasoline is less dense than water, so it's less than 55 kilos). versus say 1000 kilos for the net vehicle weight. 5% increase lang ng full tank vs. empty tank.
For me, full tank to the brim then wait till the gas indicator lights up then full tank again. But I make it sure that the next gas station is less than 40 kms. away para hindi matuyuan.
Well...assuming a full tank of fuel is 50Liters. Quarter tank is 12.5L, thats approximately 12.5Kgs or about 27.5 lbs. If you are overweight, why not just lose some weight and put a full tank every time? That way, you are healthier, will look better and you wont have to worry about these things? heheheh
guys, can I get a confirmation from you that maintaining your fuel tank at below 1/4 full would have a less efficient fuel consumption compared to above 1/4 full? Coz I noticed that parang mas malakas ang consumption on that setting (below 1/4 full) compared to maintaining a fulltank.
eto isang thinking ng kasama ko sa opisina; pag full tank ka, there's no vapor space sa loob ng fuel tank so walang chance na magevaporate ang fuel mo (gasoline is very very volatile). pag near empty ka na, say 1/4 tank, malaki vapor space sa loob ng tangke, so more chance for the gasoline to evaporate, hence mas malakas ang tsansa that you might loose some of your fuel due to evaporation. Not really sure how much of the fuel you would loose via evaporation since selyado nanam supposed to be yun tangke at wala syang vent, but it's a fairly logical assumption.
