Originally Posted by
jick.cejoco
1- the air intake tube/hose usually cracks at the bellows area (flex point). what you did is a common acceptable procedure when it is heat and age cracked. or, you can repair the crack with oxygen sensor safe silicone rtv sealant. best if you replace it with a new one.
2-don't be so obsessed with an engine overhaul. many a time car owners find it unsatisfactory service or some new problems injected to the car by poorly equipped, poorly trained "mechanics". what you can do is to have the engine resealed at the front, rear and at the valve cover gasket if the mechanical condition is still serviceable
