Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Jul 2019
    Has any body tried this product. I mean ive seen alot of Fuel saving devices in my time. Pero DOST supported daw ito
    Pinoy Inventor Junior De Jesus Gets DOST Aid >> Tech Patrol
    Since the product has been out since 2012 im sure may naka try dito (7 years na in the market) baka may mga opinions kayo
    HEC: it's Hi-Tech: HIGHMAX TURBO POWER SIMULATOR
    Quote Originally Posted by Iron Maik View Post
    which ones?
    Jul 2019
    which ones?
    un vortex generator and Khaos.
    pero Itong HTPS Dost supported daw
    the older engines did get some minor improvements. the intake plenum wasnt so advanced.
    now we have resin intake plenums that optimized airflow into the cylinder chambers.
    which vehicle are you planning to upgrade?
    Jul 2013
    My personal simple rule...
    Are you telling me this guy is smarter than the engineers hired by car manufacturers?
    Jul 2019
    hehehehe Uu nga sir. kaya im doing my research lang hoping somebody other tried it
    and whether good or bad un na experience nila.
    i dont get it
    so it's an electronic device that converts air into ozone, hydrogen, nitrous whatever
    tapos?
    how does it increase the volume of air that goes into the engine?
    how does it simulate a turbo?
    it doesn't do anything to force more air into the engine
    how much is the comish? lol
    The comish is expensive.
    It adds oxygen raw to make more torque.
    how does it add more oxygen?
    it doesn't have anything mechanical to blow more air into the engine
    let's start with the airflow sensor
    the sensor tells the ecu how much air is going into the engine and the ecu tells the injectors how much fuel to give
    when you force more air into an engine via turbocharger or supercharger, the airflow sensor detects the increased air and the ecu tells the fuel injectors to give more fuel
    how does that highmax thing increase airflow if it doesn't have anything mechanical
    it doesn't spin a compressor
    Jul 2013
    if you believe in your product and you have DOST support, siguro naman kaya mo maglabas ng konting $$$ to pay for your own domain.
    the guy used "blogspot"
    Jul 2019
    Actually sir yes all of those question are also giving our FB group a lot of skepticism. Pero even with that we are giving them the benefit of the doubt. In fact a member is offering to personally test the product as in full tank to full tank with a baseline measurement but he comes back at us with videos of monteros na nawala ang smoke hehehe.
    makakalimutan din ng mga tao yan
    tulad ng khaos
    May 2011
    It is possible. This is an old idea used in the second world by the luftwaffe using N2O or nitrous oxide. This added more oxygen that commonly found to have an average of 21% of the air we breathe. 78% of the air is nitrogen, at normal combustion below 2500°F, it does not react. The other 1% of the air is other gases. Therefore, with additional oxygen in the combustion chambers, you can add more fuel for more torque.
    This system they are talking about has the same concept of enriching the ambient air with oxygen .
    It might work.
    Oxygen is O2, ozone is O3, one molecule of oxygen more.
    and how much nitrous oxide can that thing make out of air to even make a difference
    if it even works at all
    May 2011
    Probably using an ozone generator in the air intake system
    Even if it works
    So it can make more oxygen go into the engine
    Why would you wanna do that?
    Why would you wanna lean out the air fuel mixture?
    Why would you wanna let your car's engine run hotter than it should?
    Why do you wanna risk fuel knock?
    Jan 2009
    These guys always starts with the same old premise; That the car manufacturers got the engine design wrong from the factory.
    In one of the video interviews, the moment Mr. Inventor said that the black soot that’s coming out of tailpipe is carbon dioxide, I knew that the game was up. He’s been outed. He hasn’t got a clue.
    I would bet that his gadget got most of its internal circuitry from a bug zapper.
Highmax Turbo Power Simulator
