Results 71 to 80 of 141
- Aug 2003
- 9,720
April 22nd, 2004 10:18 AM #72
here's the price:
K&N filter = 3,500 (washable- recomended)
SiMOTA = 550 (disposable)
Aluminum Tube = 900 to 1,500
NOTE: sometimes you can install the filter w/o using any tube spec if the size of your orig intake hose is the same as the size nun Filter opening connector.
APeXi la pa sa country unless some individual brought it locally.
For mmore details cont me * 09178474315 SNY
- Nov 2002
- 194
April 22nd, 2004 03:37 PM #73snyc3,
how much k&n for lancer pizza 4g92, yun oval shaped? i think i can use the stock intake, but needs adaptor ata.
thanks.
April 23rd, 2004 04:15 PM #74
mas maganda ba yung cone type na filter na sa ibabaw lang yung butas tapos metal yung sides? or mas ok yung filter yung sides?
I'm thinking kasi kung smaller yung surface area nung filter itself, with all other things being equal, more air per square inch yung dadaan sa filter kung maliit yung surface area compared to a filter with a bigger surface area.
Per nagagandahan ako dun sa metal yung sides. :D di kaya mas mahirap linisin to compared to the exposed cone type filter?
BTW, I'm talking about simota filters.
April 23rd, 2004 05:24 PM #75
Adaptor is already included in the filter for k&N. 3500 din price nyan. Basta 3" ang intake tube mo ha...
SIMOTA filters are not recomended for cleaning... disposable e2. You can try cleaning it with the cleaning solution pero mag hihimulmul (tama ba?) yun threads and may cause it to be sucked in by the engine intake. Ok din simota pero disposable... Yun metal sa sides nya ang purpose is for the air to be colder daw, parangshield sya o heatsink, pero sa init sa pinas mainit pa din yun! kaya K&N proposes the users to put a tube from teh front bumper w/c ends near the air filter para malamig yun air. (same principle sa intercoolers)
April 23rd, 2004 05:53 PM #76
yung 3500 na K&N universal application ba? nagpaquote kasi ako para sa ride ko (96 galant ss), 6k bigay sakin. drop-in type filter.
April 23rd, 2004 05:59 PM #77
OPen typ yan, ssaloon. pero mahal yun 6K, ak ko tito ko coz they distribute it here sa Pinas. dapat drop in price is bet ween 4 to 5K lang retail. Try ko ask post ko sa yo tom. if avail and if kano...
April 23rd, 2004 06:05 PM #78
About the gain, you will gain a max of 10% power and at least 5% sa fuel economy. You will notice na tatahimik konti exhaust mo coz of free flow air sa engine. Estimate ko lang e2 sa personal use ko sa Accord 2.0 am not sure if it has the same effect sa other engine brands... More air means more power to burn the Fuel, More air means all the fuels getting inside the combustion chamber are well burned up.
Remeber yun straw?
2 straws, one inside a bottle of VODKA the other asa air. If you sipped on the 2 straws * the same time mas madami kang masisipsip na air but if you close the straw getting air then you will get more of the vodka(sarraaaapp) hehehe... w/c means more fuel consumption. HIK!*
- Nov 2003
- 89
April 26th, 2004 08:25 AM #79guys tanong ko lang, alin mas ok ma air filter. mas okay ba yung open type or yung may heatshield. i saw it kc sa magazine and parang palagay ko mas ok yung may heat sheild yun nga lang limited ang pasok ng air. What do you think?
April 26th, 2004 03:50 PM #80Originally posted by snyc3
personally, i'd think thrice, before buying that toyota brand new rack and pinion, to fix my 2003...
rack and pinion repair
