Page 1 of 3 123 LastLast
Results 1 to 20 of 48
    Oct 2007
    Need help po regarding my Ford Lynx 1.6 m/t 2000
    Car Info:
    1. Engine - EFI with coil packs (no distributor)
    2. Transmission - Manual Transmission
    3. On-Board Diagnostics - OBD1
    4. Stock/Unmodified
    Condition/Symptoms:
    1. Car idles or runs fine when engine is still cold (with or without aircon). May hatak po yung kotse (even uphill) and walang hesitation or misfire. Upon idle with at least 5 to 10mins engine running, RPM needle is steady at 900 RPM (without aircon) and 850 RPM (with aircon)
    2. When engine is already hot (or should I say reached its operating temperature), let’s say 30 minutes running (worst 20 minutes if stuck in traffic), the following will be noticed:
    a. Upon idle without aircon on - nagmimisfire from time to time, nagddrop yung needle to the point na almost mag stall na engine and then biglang taas then balik sa 850 to 900 RPM. In short, if without aircon, will misfire but will not stall at idle.
    b. Upon idle with aircon - kapag nag engage na yung compressor - after 2 seconds, engine will stall. However, upon starting, nagsstart naman agad engine. In short, with aircon, will misfire and stall at idle.
    c. When running/cruising with or without aircon - nagsstumble/jerk po yung makina dahil sa misfire (which I think equivalent sa pagstall kapag naka-idle). In short, if with or without aircon, will misfire/jerk/stumble/hesitates while cruising.
    3. When engine is already running for almost 45 minutes to an hour, the above symptoms will worsen noticing the following:
    a. Upon idle without aircon - Namamatay makina if hindi nakapress yung gas. In short, if without aircon, will misfire and then stall at idle.
    b. ** What I do when naka idle ako, especially if traffic, nakaapak lang ako sa gas para hindi mag stall yung engine.
    History of repair/parts replaced to date - Ito na po mga pinalitan kakahanap ng solusyon:
    1. Spark plugs - stock - Yung pinagpalitan ko ay brown yung sunog, so I guess maganda ignition system ko.
    2. Coil packs - 1 year old - Tried unplugging one coil at a time at nagrereact makina, so I guess working din mga to. I even pointed the coils sa cyclinder head at may spark naman.
    3. Fuel pump - new
    4. Fuel filter (high pressure and low pressure) - new
    5. Air filter - new
    6. Thermostat - new (no overheating issue pero pinalitan ko nalang kasi mukhang luma na at sira na rubber grommets
    7. Water pump
    8. Timing belt and related parts
    9. Aircon Belt
    10. Alternator Belt
    11. Throttle body - newly cleaned
    12. MAF Sensor - newly cleaned
    13. Knock Sensor - Japan surplus (the old one is already melted)
    14. Camshaft Sensor - (replaced last 2005 due to stalling problem)
    15. IAC Valve - surplus *
    * Now, the latest one replaced was the IAC Valve. This was done just last week, September 10, 2016, in Banawe. I arrived in Banawe (from Makati) na mainit na makina at namamatayan na. Upon changing IAC Valve, hindi na namatayan at idle even with aircon on. We even test drove it. Total running time siguro ng pagtetest is about 3 hrs (note wala masyado pahinga kotse dahil pagkadating ininspect and inayos na kaagad). However, nung umayos yung stalling problem nya, napansin naming na nagmimisfire yung kotse at high RPM (4k and above). They dried diagnosing but to no avail. Nevertheless, satisfied na ako nun kasi di na nagsstall, kaya I called it a day and then umuwi bound for Makati. On my way home, bigla nalang po bumalik yung sakit niya. Parehong pareho padin. Until now, ganun po parin. Di ko na kasi naasikaso ibalik since busy sa work.
    Tingin nyo sir, IAC Valve kaya problem? Nakakapagtaka kasi okay naman nung una. Or may iba pang culprit? If other than IAC Valve, ano kaya relation nya sa rineplace na IAC Valve kaya gumana sya nung una. Gusto ko na din sana ipa-scan kaso wala ako makitang nagooffer ng OBD 1 scanner. Syempre, gusto ko din medyo handa ako bago pumunta ulit banawe para di po ako mataga.
    Sorry po sa haba. Para kumpleto lang po details. TIA mga sir!
    Nice and detailed.
    How does the engine look from the inside of the oil cap? Is there sludge?
    How long does it warm up to operating temperature? 30 minutes?
    Hindi namention ang replacement ng oilpump. Baka hindi na sya operating at maximum..
    Curiosity. .ano odometer reading 250k?
    Oct 2007
    Nice and detailed.
    Sir,
    ODO is 200k.
    Normally naman po, the temperature needle rises up to almost midde mga 10mins palang. Mas mabilis magrise if upon start kotse eh iddrive agad.
    Yung 30 minutes i assumed lang na thats the time talaga na mainit na makina. Consistent po kasi. Parang may timer yung kotse. 20-30 minutes magpapalya na.
    I think sa oil po, okay naman. Actually kakachange oil ko lang po to liquimoly with engine flushing. Every year po ako nagpapalit oil. Last year was royal purple. Usual comments ng mga mekaniko eh "maganda pa makina nyo sir", tho di ko alam bakit nila nasasabi yon. Hehe
    Feb 2009
    what is the model year of the car? Sounds like ignition problem. Try substituting the ignition coils with known good ones or have the coil waveforms looked at on an oscilloscope(better if you can have the waveform patterns printed or saved electronically for email).
    Oct 2007
    Thanks sir. Why do you suspect that its the ignition coils? San po shop ang nagooffer ng ganyang service? Thanks!
    Feb 2009
    at a higher operating temperature the internal resistance of the ignition coil is also higher. it would be easier for the high voltage to dissipate to the nearest ground path which is the cylinder head versus the spark plug that is exposed to the higher pressure of the compression. electricity is very lazy, it will take a short cut when it can, hence the spark happens at the most convenient location than at the pressurized spark plug gap. what you can do too, in the absence of an oscilloscope is to measure the primary and secondary resistance of the coils. if you have a megger(high voltage insulation tester), is to inject high voltage and see if the spark happens around outside of the coil housing
    Oct 2007
    Thanks sir. Very informative. Other than the said testing, i have 2 sets of old coil packs na nakatabi lang sa bahay. Nagpalit ako kasi nung mga nakaraang taon dahil pumapalya, pero hindi pala yun ang culprit. Try ko din kung okay din mga yun.
    Curiousity lang is, bakit nung sinalpakan ng ibang IACV gumana sya at di namatayan? Pero kinalaunan, bumalik din sakit.
    Feb 2009
    Quote Originally Posted by Jeh View Post
    that's just it. it wasn't the cause, maybe a coincidence. wrong guess in my opinion. what model year is the car?
    the IACV does not cause misfire under normal usage. the most vulnerable is the ignition coil because of heat.
    Feb 2009
    can you identify your engine? was the car manufactured in the u.s. or europe?
    Jun 2005
    Sa lynx ng pinsan ko, turns out it was just faulty high tension wires.
    Replaced the high tension wires no more, problem.
    Oct 2007
    The engine is similar to the engines of mazda 323 if i am not mistaken. Actually, parehong pareho sya sa mazda familia or protege yata. ZM-DE engine for the 1.6 variant.
    This car was released 1999-2000.
    Oct 2007
    Quote Originally Posted by sirkosero View Post
    Same din sir ng symptoms? I may have overlooked yung coils kung yun nga ang sira. All along I was focusing sa intake area kasi ang suspect ko is lack of air kasi at idle lang namamatay. Will try to inspect/replace coils. Ang mahal kasi nito for OEM, 4k x2, so 8k yata.
    Aug 2013
    mga possible na sira bro.
    -ignition coil
    -ECU (leaking capacitors kasi luma na)
    -MAF sensor (kung mali reading nito lalo na kapag mainit na makina o mainit ang outside temperature, erratic ang idling)
    -oxygen sensor
    kung OBD1 ka, may kailangan kang ishort sa diagnostic box or sa ECU habang naka ON position yung ignition key (hindi naka start makina), tapos mag blink si CEL ng error codes mo. baka meron sa internet kung paano gawin.
    Oct 2007
    Quote Originally Posted by innova2013 View Post
    -ignition coil
    -oxygen sensor
    Thank you sa input sir.
    - ignition coil -will check this tomorrow
    -ECU-leaking capacitors-can this be fixed??? O palit ECU. Ang alam ko ginto to hehe.
    -MAF sensor-negative sir, hindi po erratic idling ng lynx ko. Even when hot, nagddrop lang when ngmisfire pero 1 in 20 seconds siguro. Di yung maalon na idle
    -O2 sensor- triny ko na hanapin sir pero parang walang sensor na nakakabit sa exhaust from headers to muffler. If i am not mistaken, yung 2.0 variant lang may o2 sensor.
    -OBD1 - ito po talaga need ko kaso wala na ako mahanap na shop na may obd1 scanner. Puro OBD2 po. Also, walang CEL (i mean walang ganun sa instrument panel) ung car kaya obd talaga need ko to check if may trouble codes.
    Aug 2013
    Narerepair ang ECU. depende sa sira. kung leaking capacitors lang, kayang kaya ng mga eletrical shop yan. hanap ka na lang ng mga shop na may ECU repair service.
    try mo tignan o inquire sa mga bosch centers, baka may OBD1 scanner pa sila.
    Oct 2009
    wag sana COMP BOX
    pero pa check mo na din.or pwede mo din buksan baka may mga leak cap (LOBO)or may sunog na resistor.na rerepair naman yang mga yan.wag lang talaga spider type IC.kung transistor regulator lang. may nabibilan..
    Oct 2007
    Quote Originally Posted by jaypee10 View Post
    wag sana COMP BOX
    If transistor culprit sir magpapakita ba yan sa trouble codes or visual inspection will do? Thank you
    check mo uli cam sensor, gamitan mo ng blower para simulate mo init. since MAF ang system check mo na din kung walang pumapasok na air na hindi nasusukat ng maf like yung mga vac hoses.
    Jan 2009
    Just throwing this out...
    I think the clue here is that, the engine appears to run better when cold than when hot.
    Simply put, when the engine is cold, the ECM goes into open loop. It means that it will ignore the O2 sensor and use the preset air-fuel table stored in the ECM program. This program is usually biased towards a 'rich' A/F mixture. Once the engine warms up (as dictated by the coolant temp sensor), it goes into closed loop and air-fuel mixture is computed based on the measurements provided by the different onboard sensors, including the O2 sensor.
    If the O2 sensor is faulty and isn't providing the correct output, it will usually cause a CEL. However, it may be possible that the ECM is still seeing the sensor to be within the acceptable parameters based on its programming, but in reality, is already giving out erroneous signals.
    Oct 2007
    Quote Originally Posted by t2erns View Post
    Thank you sir. Pero diba dapat ang cam sensor, if mainit na, hindi aandar not until lumamig ulit yung sensor? Ganun kasi symptoms ng ibang lynx per reading sa ford club. Umaandar po kasi agad eh. Or can it be failing na rin sya?
    Sige sir test din namin kung may vacuum leak.
[Need Help] Ford Lynx - Engine misfires and stalls at Idle when engine is warm (worst if with A/C)
