Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    went to true value ATC yesterday and looked around for synthetic oils...how would you know kung totoong synthetic oil? I mean iba-iba nakasulat eh, meron 100% synthetic, yun iba fully synthetic, yun iba naman synthetic lang nakasulat...
    so among those na nabanggit ko ano yun totoong synthetic dyan? kasi I assumed na dapat 100% synthetic ang "real" synthetic...tama ba ako?
    Aug 2004
    Actually, even many synthetic oils have mineral oil "stock". You have to really research to find out.
    Jun 2006
    Maybe it will help if we list the 100% synthetic oils and the synthetics with mineral base.
    From what I know the following are 100% synthetic or Group IV oils:
    Motul 300V
    Motul 8100 Xcess
    Royal Purple
    Synthetics with mineral base:
    Caltex Havoline Energy
    Dont know about these. I suspect they are mineral based but I'm not sure. can someone pls chip in:
    Shell Helix Ultra
    Petron Ultron Race
    Castrol RS
    Mobil 1
    Caltex Fully Synthetic
    Motul H-Tech 100
    Castrol Magnatech - synthetic with mineral base
    Emerat - mineral
    Pitt Penn - mineral
    hehehe konti lang maiaambag ko nakalimutan ko na kasi ang iba. . .
    Jun 2006
    Castrol Magnatech is actually semi-synthetic oil.
    Quote Originally Posted by userfriendly View Post
    Motul 300V
    Motul 8100 Xcess
    Royal Purple
    Shell Helix Ultra
    Petron Ultron Race
    Castrol RS
    Mobil 1
    Motul H-Tech 100
    kaya pala cheap yun motul h-tech sa mga mall based hardware kasi mineral base...kasi I think mura siya for a 100% synthetic oil diba?
    pero it says in the package na 100% synthetic siya ah...?
    ooops my mistake, kaya pala mahal P250+ per liter kasi dito . . .
    Jun 2006
    pls dont get me wrong. I said I dont know if they are 100% synthetic or mineral based synthetic. I only suspect they are mineral based. I may be wrong and thats why I asked for someone to confirm.
    Motul 300V
    Motul 8100 Xcess
    Royal Purple
    Shell Helix Ultra
    Petron Ultron Race
    Castrol RS
    Mobil 1
    Motul H-Tech 100
    basta po fully synthetic ang nakalagay fully synthetic siya talaga
    mobil1
    castrol rs
    shell helix ultra
    kapag synthetic based/blend po eto po yung mga semi synthetic
    castrol magnatec
    mobil s
    shell helix plus
    kapag mineral oil po ang nakalagay e mineral oil po yun
    shell helix super
    mobil xhp
    Jun 2006
    Hindi lahat ng synthetic oils ay talagang 100% synthetic. Majority are made from hydrocracked oils. Hydrocracked oils are very highly refined oils. These are called group III oils which are different from group IV oils. Group IV are true synthetics or man made.
    Basically, Mobil sued Castrol for marketing and selling a group III oil as a full synthetic. The court ruled in favor of Castrol. So in effect the courts defined group III oils as full synthetics.
    So now there are:
    1. mineral oils or dino based oils
    2. semi-synthetic oils which are oils that contain less than 30% synthetic stock
    3. full synthetic oils that can be further classified into Group III and Group IV oils.
    Nakakalito no.
    Eto ang better explanation: http://www.synthetic-oils-wholesale....p?route=whatIs
    Jun 2007
    royal purple ba full synthetic? entry level niya?
    Nov 2003
    not all oils labeled as fully synthetic are real synthetics.
    castrol RS is definitely not.
    Motul is for the higher 8100 and 300V lines but i'm not sure if the h100 is from a group 3 or group 4 base stock. it's still synthetic but it is the entry level of motul.
    royal purple is made from a group 4 base stock so basically the highest in the market except for the group 5 which can only be found in ester based oils like redline and 300v.
    i doubt any other locally available oil can match the base stock and additive package of royal purple for the same price.
    Jun 2007
    Quote Originally Posted by speedyfix View Post
    thats why nagpalit ako, good performance at more cheaper kaysa sa iba
    Aug 2007
    Are there any stock vehicles na available sa market natin na 'required' ng manufacturer ang full synthetic oil? para kasing 'recommended' lang naman, di ba.
    Aug 2004
    Many high performance vehicles and engines require synthetic, as well as some regular cars that have long change intervals.
    it's good to know that RP is of a high quality oil..
    migs, anong magandang viscosity sa RP for a diesel? mitsubishi adventure to be exact...
    IMO kaya synthetic or fully synthetic ang required ng almost car manufacturer sa ngayon ay dahil mahaba ang warranty na 3yrs or 100K kms… sila rin kasi ang mapeperwisyo if engine breakdown arises within that period….. sa synthetic nga naman assured na ang protection ng engine, dagdag income pa dahil sagot naman ng owner ang oil to be use eh.
    Marketing is great.
    Nov 2003
    washburn, yep tama ka dyan.
    DonT, all porsches, mercedes, bmw's and audis require full syn oil. same goes with the even higher brands like ferrari and lambo.
    shadow, we've got the 15w40 diesel oil na RP in the shop. perfect yun
    Aug 2007
    ^ Thanks for the info. How about Diesel Engines..when would you recommend to start using synthetic oils? I have read somewhere that diesel engines tend to break in a lot longer compared to gasoline engines. Maybe you can shed more light on this.
    Nov 2003
    start using the full syn on diesel oils around 10-15k kms na
another engine oil question....
