Results 1 to 20 of 20
    Mar 2013
    Fuel System
    Check filters. replace if dirty.
    Check fuel injectors. clean them via DIY or get to a shop.
    Check air filter. might need replacement also.
    Check MAF sensor.clean if dirty.
    Good fuel system?
    Check oil viscosity. Might be too thiick.
    Check engine compression.
    Check engine temp/radiators.
    sounds like you need top/overhaul. Pa compression test mo, and leak test na din para malaman kung top lang or overhaul na talaga.
94 Lancer Gli SOBRANG LAKAS SA GAS AT MAUSOK
