Hi, anyone out there.... engine won't catch, checked fuel delivery lines no fuel i suspect engine shut off switch stuck in off position, any other issues i should look into? Thanks
Check if solenoid cable have power supply when you start. Also check for continuity of the solenoid coil. if you can connect it directly to the battery then start. when you connect it directly and you hear a click then the solenoid is ok.
