Results 1 to 5 of 5
    Hi, anyone out there.... engine won't catch, checked fuel delivery lines no fuel i suspect engine shut off switch stuck in off position, any other issues i should look into? Thanks
    Fuel pump, open fuel lines, clogged filter or lines.
    Jun 2004
    Check for air getting into the fuel injection system. Does your engine still have a fuel priming pump?. If it does, maybe you can manually prime your injection pump and remove the air from the injectors.
    Can also be due to dirty fuel filter.
    Oct 2007
    Quote Originally Posted by nik91061 View Post
    Check if solenoid cable have power supply when you start. Also check for continuity of the solenoid coil. if you can connect it directly to the battery then start. when you connect it directly and you hear a click then the solenoid is ok.
    Nov 2003
    check din the glow plugs kung diesel.
'94 exJDm prado/1kzte-engine won' catch
