To my fellow Tsikoteers , Kailangan ko po ng expert advise nyo. Sana po matulungan nyo ko.
One of my cars is a 90 corolla GL 16 valve which I truly loved since it's my 1st car.
Here's what happened po mga Sir:
1. Nag halfway yung temp gauge ko then i noticed smoke coming from reserve coolant container, I checked and it was almost empty when it cooled down i refill my radiator with almost 3 liters of water.
2. When i got home. We remove the radiator cap then water is going upward instead of going down upon pressing the gas pedal. When we put back the radiator cap water will came out from the coolant reservoir overflow hose upon reving the engine.
3. My cousin prepared a pressurized hose with water then he removed the butterfly underneath the radiator to flush and replace the water/coolant inside the radiator. Once he feel that the warm water coming out is already cold he ask me to start the engine and he was surprised after a minute or two the water flowing suddenly becomes warm.
4. Habang start ang makina, we remove the engine oil cap on top of the engine then cover it with his hand without revving the engine then oil will shoot up to my cousins palm.Sabi nya dapat daw alang langis na tataas at dapat hangin lang ang mararamdaman.
5. Bale i noticed din po na mabilis uminit then matagal lumamig yung engine. Pag uminit po halos di mo mahawakan yung engine sa sobrang init yung sa may top cover po.
6. When i got the car several months ago. Naka experienced na ng tatlong overheat yung sasakyan, So got radiator overhauled, nag try na ring mag coolant pero parang nakasama.
Regards,
