Results 1 to 10 of 11
- May 2006
- 424
July 12th, 2006 10:31 PM #1Hi, for all mechanic and experts..
For 4DR5 engines, assuming with consistent oil change and tune-up. The unit/vehicle has runned 200+K mileage in 6 years.. company service kasi. What problems do we expect? Should we expect Piston replacement or overhaul?
Timing belt and other belts have been change. Evaporator have been changed na rin.
200K+ mileage is way too high, di ba?
Any inputs...??
- Dec 2002
- 2,335
July 12th, 2006 11:29 PM #2sa diesel engines not really kung properly maintained sya. On the other hand 200K km in 6 years? mukhang bugbog. That's 30K km/year! Palagay ko ready ka for at leasta top overhaul.
- Aug 2004
- 136
July 12th, 2006 11:44 PM #3hi dude,assuming 230 km a day ang tinatakbo ng oto mo,for 6 yrs ,sa tinign ko kailangan mo na nga ng full engine overhall, d lang top over para isang gawaan lang ,papalitan mo nang dapat na palitan .pamasada ba yang oto mo ?
- May 2006
- 424
July 13th, 2006 09:15 AM #4Originally Posted by g-shock
Tsikot Member Rank 3
- Dec 2002
- 551
July 13th, 2006 10:58 AM #5If the engine is maintained properly change oil every 5k km or 3months and there are no signs of oil consumption, hard starting or even smoke belching then you dont need to have it overhauled. But to make sure go have a compression test on the engine then you can decide if the engine needs to be overhauled.
BANNED BANNED BANNED
- 3,790
- May 2006
- 424
- May 2004
- 102
July 14th, 2006 09:19 AM #8sir, kung sa basic inspection nyo eh ok naman so need for overhaul agad.
use a good engine flush and a good oil ok pa yan.
- 3,790
July 15th, 2006 01:33 PM #10
Palitan mo nalang agad ng timing belt para sigurado, baka kasi medyo matagal na din napalitan yung belt at nalaspag na ng gamit. Bago ka mag test kung mausok yung engine, check mo muna kung malinis yung air cleaner. Pag madumi yun, for sure pag nag rev ka e mag uusok yun. Kadalasan kasi yung lang ang cause ng smoke bleching at dirty fuel filter. 3 years din ako nakagamit ng second hand L3 van with 4D56 engine, wala naman ako naging problema. Just followed the maintenance regularly.
Just sharing my experience.Last edited by kupaloids; July 15th, 2006 at 01:37 PM.
Megawatt charging: https://www.youtube.com/watch?v=usUxO7y4z_E
BYD Philippines
