Results 1 to 10 of 13
October 15th, 2010 10:12 AM #1
Mga Paps,
I have the the manual and it says "tighten 2-3 times" and "torque to specs which is 118 Nm" for 4D56.
Other manual for other engines says "torque to specs then 2x 90 degree sequence"
Another manual for another engine says "Torque to ### Nm, then loosen, then torque to ### Nm, then 2x 90 degree sequence"
So many methods, my question is what is really meant by the "tighten 2-3 times" for the 4D56? is it 2-3x 118 Nm or 2-3x 90 degree or some other angle?
Any info my dear paps? because what i did before was torque to specs then angular tightening method (2x 90 deg). Thanks
- Jun 2010
- 76
October 16th, 2010 01:46 PM #2ang dead bolt nyo ba ay allen na 10 ang higpit nun ay 3 times na higpit ang gagawin mo ay hatiin mo yun 118 sa tatlo para maging tatlo na higpit kasi kung 12 points ang bolt ng head nyo yun ay plastic region ang procedure nun
October 18th, 2010 09:45 AM #3
- Jun 2010
- 76
October 18th, 2010 10:24 AM #5
lexxus,
Any additional info on the ff?
1. How about the loosening method for the bolts (manual says 2-3x)? any specified turns to loosen the bolts?
2. Grade of the 10 mm head bolts for 4D56B? M8, M12, M14, etc?
3. How many times those bolts can be reused? 2X or 3X?
Sorry, masyado madami tanong. just searching for a foolproof way so as not to do the repairs again.
October 22nd, 2010 01:02 PM #7
October 22nd, 2010 03:41 PM #8
October 28th, 2010 07:39 PM #9
thanks jick. how about the retightening issues, shall i use the same torque specs again?
October 29th, 2010 02:55 PM #10
quite a while back, the dealership where you bought the car used to retorque the fasteners in the engine and suspension. these days, dealerships are free of that burden because of plastic region bolts or fasteners like yours. sure, if you want to retighten the bolts, use the same specs
That makes sense. Higher elevation has lower atmospheric pressure and even if the cooling system is...
