Results 1 to 5 of 5
October 3rd, 2011 10:53 PM #1
sino na naputulan neto? twice nako naputulan.buti di nagoverheat. i'm in search for a brand new replacement.
surplus shops won't sell the bracket alone unless you buy the alternator.
reinforced it with a flat bar welded at the front side of the bracket. bracket is a tensioner bolt type. not the type that you pull the alternator then tighten the bolt along the slot.
October 4th, 2011 12:51 AM #2
If you can't find a shop selling you the part, maybe you can have it made for you?
There is a shop in caloocan that have a five axis water-jet. Maybe you can contact them to use the broken bracket as a pattern to let them cut you a new part from sheet steel?
LINK: Waterjet Cutting Center Philippines
October 4th, 2011 11:33 AM #3
thanks for the info sir GH. great info on this. nearby machine shops would be my option for the meantime for the purpose of having a "sample" for the cutting service if ever. thanks
- Jul 2003
- 573
October 13th, 2011 12:13 PM #4There has to be at least two bolts and screw for the alternator, both are tightened/torqued after setting the belt tension adjustment. Perhaps the other bolt/screw was left loose?
October 13th, 2011 02:10 PM #5
looked for the video. it would seem, according to the video, the car in question was purchased by...
China cars
