Page 1 of 2 12 LastLast
Results 1 to 20 of 44
    Anyone running this here? I am told it is the best. Made by Mann Hummel.
    http://https://www.mann-hummel.com/fileadmin/user_upload/service/catalogues/pdf/ProVent_en_2013.pdf
    Features include a synthetic filter media, pressure release valve and drain for oil return to crankcase. Pricey though, at Php7k+ est. Php2K+ for the filter media replacement.
    maganda yang provent. saw a provent-style OCC in an australian forum. much cheaper than provent but still expensive.
    ProVentŪ Style Oil Catch Can Review - Chip Tuning Australia
    Looks like a Chinese copy. Ang mahal pa rin Thanks for the link though. That should be priced much lower. Methinks this is from Robert who used to work at ChipIt.
    I'll try to contact the local Mann Hummel dealers for more info.
    Apr 2012
    kung totally dry at walang trace ng oil yung outlet line palabas ng occ then effective nga yan. if my traces pa rin ng oil yung line na papasok sa turbo casing then pareho din ng generic yan na may nakakalusot pa rin na oil. everytime i drained the occ, i checked the line palabas ng occ at meron pa rin oil na nakakalusot. considering yung na collect na oil compared sa walang occ, at least na-minimize at na-prevent yung oil mapunta sa sa turbo casing, ic at intake m/f.
    Ah iba ba yung link ko sa ChipIt? I thought same lang.
    Please let us know if you find one locally.
    Afaik iba yung Chiptuning sa Chipit, they are separate companies. Chiptuning is a dealer of Chipit. Dapat nililinaw nila yun para walang confusion sa customer support, warranty, etc. Typical ng startup, siguro ginagamit din yung name ng Chipit to boost sales.
    Re: Provent I'll let you know sir. Just contacted Mann Hummel Phils, they will refer me to a local dealer. They're just checking which one has stocks of the item.
    Aug 2010
    what particular vehicles locally need this?
    how much does this cost in the local market?
    Jul 2010
    Im buying kapag may locally available na & sana maglabas din dito ng washable filter media..
    For me, Oil catch can is one of the most important upgrade for a turbo diesel.. Thats my modified catch can after running less than 8000km..
    Apr 2012
    masyadong mahal yan for an occ in fact, yung mga generic dito sa atin na occ ay more than capable naman na to trap the oil preventing it before going into the turbo housing, intercooler and finally ending in intake manifold.
    ^Pero kung euro car like BMW or Merc siguro ride ko ganyang OCC na rin ikakabit ko. hehe
    Para astig talaga sa protection.
    *Ry_Tower
    Afaik some VW TDis have this installed as OEM. I would imagine dapat lang meron na from factory yung mga premium German brands nito kung VW lang meron na. Just in case maambunan ako ng pork at makabili ako ng German pwede ko ilipat dun yung unit.
    *monty_GTV
    Yes sir a bit expensive but it should do the job much better than the generic OCCs. As I mentioned above we can transfer it from vehicle to vehicle if ever it's time to sell the car. Also at around 7K I wouldn't consider this expensive in relation to the cost of modern diesels, which are now 1.1M up. That's not even 1% of the car.
    *TheGreenThing
    Your OCC looks pretty effective sir. Has any oil made it past the OCC into the intake? Is there any water in the oil?
    *crazy_boy
    Yup, ang laki ng inlet and outlet, 25mm for the 200. Pero yung 16mm of the 150 should be enough. Yung filter element around 80,000-100,000 Kms of use daw. Not bad hehe.
    I'll try to update this when info on availability comes.
    Remember this largest DIY OCC in Tsikot?
    Eto pa rin ang gamit ko almost 2years na pero may nakakalusot pa rin na mist. I will be experimenting on stainless steel mesh filter like yung nakakbit sa fuel tank. mukhang mas effective in coalescing oil vapour.
    Naisip ko sa salvage yard sa UK baka may mas mura. Built-in on most engines nila kasi ang OCC. Another good option is this crancase ventilation from cummins. Clearing the Fog with Crankcase Ventilation
    Yung filter naman hindi kailangan parati palitan. Baka every 20-30k km siguro bago palitan yan.
    Jul 2010
    Nope!!! Our catch cans here including mine are all just a bunch of bling items.. & its efficiency is very low(unmodified) compare to that provent.. What makes the provent so effective is the pcv gasses revolves around the cylinders like a centrifugal force & separates the oil from the fumes..
    Just my 0.02
    Isa pa, yung sa provent malaki yung nipple so hindi sakal yung blowby gas.
    Sa diesel yata 20+mm.at least for the 4m40 21mm yung nipple na kailangan.
    Nov 2004
    Saan ba garantisado magpakabit ng oil catch can? Yun sanang modified para mas epektib?
    Sent from my THL W8s using Tapatalk 2
    Halimaw, kung gusto mo magandang OCC, hanapin mo yung provent na naka post sa itaas.
    Nov 2004
    idol cb yung budget meal lang sana pa install ko
Grand Daddy of all Oil Catch Cans
