Quote Originally Posted by batosai View Post
Sir ndi q nga po binuksan ang cap nung mainit pa kasi natatakot ako, alam ko matindi ang pressure once na nag overheat ang engine, sir any hint or idea kung panu ko malalaman if may tama ang gasket or head before ako mag consult sa mekaniko, and one thing na napansin ko after this overheating parang lumapot ung oil ko against sa dati upon checking sa dip stick, cause din po kaya ito ng overheat, I had my oil change just a month ago ( Shell semi-synthetic gamit ko ) do i need to change oil again?
TIA
easy telltale signs of damage to check are:
1. check the oil filler cap for milkshake like emulsion
2. check the oil dipstick for oil/antifreeze emulsion and for corrosion on the dipstick end
3. check the radiator cap, surge tank gasket and return hose for swelling of rubber components
4. check the tailpipe for steam when running engine. occasional steam upon start up is normal (droplets of water coming off the exhaust even with the engine warms up is a sign of trouble)
5. listen for engine rough idling or puffing at the exhaust tail pipe.
