Results 1 to 20 of 22
    Notes:
    1. Temp doesnt go up when its partially working. Temp goes north when pump dies.
    2. Fuel consumption goes up considerably.
    3. Throttle response isnt good- delayed power.
    4. Transmission seems jerky.
    5. If you start the engine again, tacho goes low-ecu senses hot engine?
    6. A/C isnt as strong
    7. Failure was imminent at 250,000km
    8. Top radiator hose is warmer significantly than the bottom hose
    9. Main failure: bearing siezed
    10. Computer readout: overheat even before waterpump failed.
    Apr 2014
    When you loose majority of your coolant.
    Quote Originally Posted by chronicle View Post
    if the pump fails completely, then yes
    in some cars, the water pump leaks because of its age..
    although strictly not water pump failure, it does lead to engine overheat due to coolant loss.
    and if this leak is hidden from view, it makes trouble-shooting so much more difficult.
    Mar 2005
    In our Mazda3, the A/C just stopped cooling. Like it was a switch turning off, it just stopped in the middle of driving. That's was like 10-15 mins before the temp gauge started to climb up... then there will be a point when it will just drop (no, it ain't suddenly cool...but you're probably not far from really big trouble.) Good thing I was already in front of Camp Aguinaldo, so all I had to do was turn around and park quickly * Mazda Greenhills. A new waterpump later, all is well again.
    Quote Originally Posted by Bravoexo View Post
    bro how old was the car?
    Mar 2005
    It's an 05...so, around 12 1/2 years old when it happened last year.
    japanese precision bearings! awesome!
    Apr 2014
    Experienced a water pump failure on a non ecu equipped car. So gauge lang ng temp ang basehan.
    Kapag naka stop, dun tumataas ang temp. Had to stop every 5 mins to refill the radiator with water. Definitely stressful. Buti nangyari sya nang gabi at less ang traffic.
    Oct 2009
    hirap ng ganyan kung sa gitna ka ng edsa tapos bumper to bumper ang trapik..
    Nov 2017
    Quote Originally Posted by jaypee10 View Post
    Minsan tanggalin mo takip then alaga lang sa refill hanggng me makita ka gawaan
    Apr 2014
    No choice pag ganyan. Tulak hanggang gasoline station tapos iwan na lang don.
    replace talaga dapat before complete failure. if that coolant level changes and the accumulated mileage is high then its time to replace that not so expensive waterpump. 2500 lng for my daily.
    Apr 2014
    I was a total noob that time. Kaya sobrang stressful. Buti yung napuntahan ko sa banawe is honest naman.
    bro may idea ka sa vios 1st gen? magkano pala labor? thanks!
    update again ..
    AC off ..
    confirmed automatic fan turns ON * 95c
    but seems too late as by 96c, temp warning light turns ON already.
    Jan 2009
    update again ..
    AC off ..
    How are you reading the 96°C? That's still normal operating temp.
    106-110°C is borderline and above 110°C can be considered overheating.
    So it's either the measured temp is wrong or it's an instrumentation problem.
    via obd scanner lang bro.
    weird thing is, fan is only triggered at 95c coolant temp; with a coolant temp warning in dash.
    when i was testing this way back, my temp went upto 98c but still no temp warning sign in dash. only since monday it started doing it (temp warning as early as 95c).
    tried cleaning this with wd40 then brake cleaner
    nada
    still triggers the fan to run * 95c with temp warning ...
    how to set the aux fan to run at maybe 88c? [emoji848][emoji848]
    mukhang pareho kami problem nito ..
    Overheat warning @ 94C
Cooling System: Water Pump Failure Symptoms
