Results 1 to 17 of 17
    Jun 2009
    Hi Sirs, any suggestions on Non-casa PMS? I will have my 60K check-up for my Honda City 2011.
    also do you have any suggestion on the Oil to be used?
    TIA!!!
    Mar 2004
    It's cheaper at Honda dealer if they still have their change oil promo. 1,095 inclusive of 10W-30 engine oil, oil filter and labor.
    Honda Cars Philippines' Official Website
    san ba location mo ts? there's a whole slew of decent car repair shops out there w/c rivals any casa
    Start first by reading your owner's manual to familiarize yourself with what has to be done at specific service intervals. From there you'll know what has to be done, what fluids and specifications are required, then you can buy your own parts and instruct the shop what to do.
    I usually have my PMS done at Motech.
    Mar 2005
    How much charge sa Motech ng mga PMS stuff like brake cleaning/adjustment and brake flushing?
    Quote Originally Posted by jmpet626 View Post
    Can't remember the exact cost but i spend 1K more or less for the labor on the change oil, brake cleaning and wheel alignment. This includes the 20% discount i have (or their regular promos) from the discount card i availed of. I bring my own oil, filter, and brake cleaner.
    Oct 2015
    Some dealerships' labor charges are cheap enough, specially if they have a cash discount. Yun lang they have hidden charges that normally fall under "workshop materials" or "sundries" or other BS.
    For me if you go to an independent or service chain, the after service warranty (owning up to eff ups) is the most important thing and sometimes not worth the cheaper rate. It helps to know someone who already has service done there regularly.
    Jun 2009
    Thanks Sir! i am located in Pasig. I bought the car 2nd hand with no casa records, so it might be difficult to track what to replace. in anycase i will try motech...
    Guys any other suggestions? how about Zafra motors any feedback?
    Quote Originally Posted by frost2 View Post
    Since it has no CASA record, best to change all your fluids (transmission, brake fluids, power steering, fluid) and filters (fuel filter and air filter), then replace the belts as well.
    kung sa pasig area, i guess ang ma-recommend ko ay ang speedyfix lang in san juan (little baguio area). iyan lang ang napag-ayusan at dinayo ko na malapit-lapit sa area niyo bro
    Mar 2004
    Go to SpeedyFix. Also drain and change radiator fluid. Important to change Automatic Transmision Fluid.
    Jun 2009
    thanks sir! i was actually looking at this shop. naka email din ako ng estimate from them
    royal purple oil change 2700
    drain plug washer 50
    air filter 500
    sparkplugs 600/pc x4 labor 400
    brake inspection and cleaning 600
    ok ba yung Royal Purple Oil?
    Ok iyang royal purple
    Para makatipid ka ikaw na lang bili ng mga piyesa mo sa suki mong spare parts shop tapos dalhin mo na lang sa speedyfix para sa pakabit
    Sent from my ASUS_Z00AD using Tsikot Forums mobile app
    Mar 2004
    600 for a spark plug? That's quite expensive. Maybe it's for 4 pcs already? Bosch Platinum spark plug costs only 200 pesos or less. Use mineral oil first and not synthetic.
    I spent 450 per spark plug when I had mine replaced for my Mazda, that's Banawe price already. Iridium plugs are really more expensive because you only replace them every 100k km.
    The Labor is expensive... Php 400 for the change of spark plug
    Aug 2008
    Anyone have any recommendations in the Taguig/Makati area?
Best Non-casa PMS
