Results 1 to 20 of 22
    Jan 2008
    OK pa ang battery, wala na gas pero may redondo pa naman, ano kaya kailangan i-check kung nilagyan na ng gas pero ayaw pa rin mag start?
    Feb 2005
    dont forget to flush the engine and have the oil changed.
    Jan 2008
    Quote Originally Posted by cocoy_01 View Post
    sir, i-DIY ko na lang muna to sa garahe namin o kung napa-andar dalhin ko sa nearest gas station for change oil? balak ko kasi dalhin sa detailing shop after.
    It should be fine, there are even carburated cars that have been in stock for the same time (even longer) that will run fine.
    Just drain/empty your gas tank to rid it of the expired gas and put in some fresh gas. Remember to also check the fluid levels especially in the radiator. Engine Oil and oil filter change too.
    Jan 2003
    check the fuel pump if it still works. hopefully there are no rodents in your garage.
    Jan 2008
    Quote Originally Posted by non-vtec View Post
    minsan may daga, sana lang di nila naisipan gawing bahay yung kotse.
    Quote Originally Posted by enzo18 View Post
    In that case, try to check the all important brake lines too.
    Oct 2007
    The gas expires in two years so puede pa yan. make sure the fuel pump is primed, or you can drain it tru the fuel the pump, leave the keys on 'ON',then
    remove the fuel hose after the fuel pump and drain. If you cant do DIY ask for the services of a mechanic. kaso baka me iba pa na problema yan parang hindi normal na pabayaan na lang nang ganyan ang isang car.
    Better prepare for a tune up, parang sobra naman pagtitipid ninyo ni hindi man lang ini start for one year.
    Jan 2008
    mark_t,
    out of the country mga tao, buti na lang hindi kinalawang.
    check mo or replace the spark plugs ..
1 Year Di Nagamit - 2002 Lynx GSi
