OK pa ang battery, wala na gas pero may redondo pa naman, ano kaya kailangan i-check kung nilagyan na ng gas pero ayaw pa rin mag start?![]()
It should be fine, there are even carburated cars that have been in stock for the same time (even longer) that will run fine.
Just drain/empty your gas tank to rid it of the expired gas and put in some fresh gas. Remember to also check the fluid levels especially in the radiator. Engine Oil and oil filter change too.
check the fuel pump if it still works. hopefully there are no rodents in your garage.
The gas expires in two years so puede pa yan. make sure the fuel pump is primed, or you can drain it tru the fuel the pump, leave the keys on 'ON',then
remove the fuel hose after the fuel pump and drain. If you cant do DIY ask for the services of a mechanic. kaso baka me iba pa na problema yan parang hindi normal na pabayaan na lang nang ganyan ang isang car.
Better prepare for a tune up, parang sobra naman pagtitipid ninyo ni hindi man lang ini start for one year.
