Results 1 to 20 of 42
    Sep 2010
    Hi yung civic vti ko kahit OFF aircon tataas ng 1/4 above normal temperature.
    Hindi naman nagbabawas tubig radiator.
    Pwede ba ang cause nito pag mali ang timing at madumi ang servo? or baka pasira na ang relay?
  2. #2
    1/3 nga normal e.. pero kung lumalagpas sa 1/2 at city drive ka lang... papalitan mo muna thermostat ng cooling system mo, at palinis mo na yang radiator mo... and do replace with coolant-distilled water mix... dont use tap water....
    Sep 2004
    Quote Originally Posted by alwayz_yummy View Post
    check the fan kung ok pa ang ikot. baka pudpod na ang carbon brush.
    May 2004
    1/4 above normal temp which means almost 3/4 of the guage.. kasi yung akin almost 1/2 yung Operating temp ko... check your cooling system.. Radiator and Cap, Water Pump, Termostat and termo Switch, Fan Belt, Hoses...
    have the water pump checked. malamang di na yun gumagana kaya kahit puno ang tubig mo, nag-iinit pa rin beyong the normal.
    pacheck mo nalang lahat that's related sa cooling system. 1/2 ang normal ko.
