Results 1 to 10 of 42
- Sep 2010
- 173
May 24th, 2011 12:47 AM #1Hi yung civic vti ko kahit OFF aircon tataas ng 1/4 above normal temperature.
Hindi naman nagbabawas tubig radiator.
Pwede ba ang cause nito pag mali ang timing at madumi ang servo? or baka pasira na ang relay?
May 24th, 2011 08:04 AM #2
1/3 nga normal e.. pero kung lumalagpas sa 1/2 at city drive ka lang... papalitan mo muna thermostat ng cooling system mo, at palinis mo na yang radiator mo... and do replace with coolant-distilled water mix... dont use tap water....
- Sep 2004
- 340
May 24th, 2011 09:14 AM #3
- May 2004
- 903
May 24th, 2011 12:57 PM #41/4 above normal temp which means almost 3/4 of the guage.. kasi yung akin almost 1/2 yung Operating temp ko... check your cooling system.. Radiator and Cap, Water Pump, Termostat and termo Switch, Fan Belt, Hoses...
diretsahan lang
- Jul 2009
- 627
May 24th, 2011 01:03 PM #5have the water pump checked. malamang di na yun gumagana kaya kahit puno ang tubig mo, nag-iinit pa rin beyong the normal.
May 24th, 2011 01:05 PM #6
pacheck mo nalang lahat that's related sa cooling system. 1/2 ang normal ko.
May 24th, 2011 06:27 PM #7
* TS: 1/2 or slightly lower is the normal. Anything above should be taken seriously.
Fasten your seatbelt! Or else...Driven To Thrill!
May 24th, 2011 06:54 PM #8
di ko masyado nabasa pala.. so 3/4 nga yan.. full check-- radiator general overhaul, thremostat replacement, water pump check, ung fan pag malakas pa ikot--ung hangin na mainit ramdam mo pa hanggang likod ok yan.. and most fans are brushless na!
pagkatapos, replace only with distilled water and coolant...never use tap water.
- Sep 2010
- 173
May 24th, 2011 08:01 PM #9Pumunta na ako sa talyer. I-schedule ako ng leak test. Buksan daw yung top ng engine check kung warp or may crack cylinder head.
Tinanong ko kung water pump ang sira, sabi kung sira daw water pump dapat diredirecho daw overheat.
Naalala ko kasi nung nagpalit water pump last year eh for Civic 1.5 liter ang nakalagay sa box pero pwede daw sa 1.6 liter. GMB yung brand. Tapos hindi sya all metal. Plastic yung sa may umiikot na part kung saan nakaikot yung timing belt ata.
May 24th, 2011 09:16 PM #10
unrelated yun... may thermostat pa ba? kung inalis mo na dapat 1/4 nalang yan kahit katirikan ng araw...pero mas ok kung lagyan mo uli, mas madali nga maatain ng engine ang kanyang working temp. and bleed mo ng maigi ung system pagkatapos... and USE DISTILLED WATER! 60-70 lang naman ang 6-liter pack...manila pure or absolute gamitin mo... wag tap water!
nga pala bago mo pabaklas head ng makina, pa-compression test mo muna, baka di naman talga dun ang prob,e..Last edited by alwayz_yummy; May 24th, 2011 at 09:21 PM.
Must have jinxed myself somehow. Was headed south around noon. A truck dropped its load of...
Traffic!
