Results 1 to 10 of 15
December 18th, 2010 09:04 AM #1
mga sir saan pede bumili ng surplus alternator near alabang area.mukhang bumigay na yung alternator ko.last day i went to san pedro naka pag start pa ako nung morning and 1click lng tapos along the way biglang nawala yung busina ko then nawala yung aircon and yung light sa instrument panel nag start syang humina like nung signal light di mo na makita yung light sa instrument panel.and bigla na lang ako namatayan.pero if itutulak tapos jumpstart ok naman pero after 5 mins. patay na uli.wala naman problem sa engine.(honda civic lx ph15)tnx...
- Oct 2006
- 40
December 18th, 2010 10:35 AM #2
December 22nd, 2010 10:22 PM #3
December 26th, 2010 11:11 AM #4
mga sir i got my surplus alternator and installed it.the problem is biglang nawala yung aircon akala ko sira then pina troubleshoot ko ok na uli after ilang testing nawala nman yung ilaw sa dashboard tapos pati parklight,headlight at taillight.ok nman yung ibang accessories like radio,and yung sa hazard.tinignan uli at nung test nya nasunog yung relay socket at konting wire then nag sasalubong daw yung negative sa socket. pinag tataka ko lng bkit pati ilaw sa dashboard nawala.nag palit lang naman ako ng alternator.tnx...
- 171
December 26th, 2010 10:39 PM #5
January 1st, 2011 09:45 AM #7
i sugest you are better off buying a reconditioned one rather than surplus, atleast reconditioned ones are newly rewind, i've had bad experiences with surplus alternators. and the price difference isn't that much.
- Jan 2005
- 445
January 2nd, 2011 12:04 PM #8Maaring hindi nag automatic ung voltage regulator. Paukat mo ung voltage sa battery habang nasa almost redline dapat yan nasa 14volts lang.
Kung ok naman baka may nasira kang grounding connections.
- Jun 2008
- 1,741
- Jun 2004
- 476
January 16th, 2011 08:05 AM #10If I were in your place I'd take the rig to Rey's Electrical (15th Ave Cubao) or to Wizzard (along Morato). Pa check mo na yan don. They also recondition alternators with warranty pa.
Nakita ko nga din sa brochure na meron, kaso sabi nung service advisor, kapag J DAW auto down lang...
