Results 1 to 10 of 14
- Jul 2005
- 122
October 7th, 2009 01:25 PM #1hi, normally nagi-start ng maayos ang sasakyan ko. pero minsan lang mangyari ito. sobrang bihira talaga pero bothered ako. minsan tick sound lang at walang redondo, pero on the 2nd try nagi-start naman ng maayos.
Things done:
1. checked the battery terminals. ok at mahigpit parin.
2. checked the battery with volt meter. 12.7V(engine off), 14.4(engine on). So ok ang battery and alternator.
I'm assuming its the starter solenoid has carbon deposit and neesds to be cleaned???. need inputs. Thanks.
car is 96 civic vti
October 7th, 2009 01:31 PM #2
same car as yours. had the same problem.
what i did was to replace the stock starter w/ a surplus reduction starter. no more problems whatsoever. ganda pa ng tunog pag mag-start!
- Jul 2005
- 122
October 7th, 2009 02:08 PM #3
October 7th, 2009 11:38 PM #4
^ got it for 2.4k ata but i've heard mas mura na ngayon. bought it from a known seller at hondaclub. 'twas shipped from pampanga pa bro
October 8th, 2009 10:00 AM #5
correct... i recently have changed my starter to a reduction one...
maganda nga tumunog and mabilis ang ikot kaya madali umistart...
got it for 1.5k from an HCP'er... from papa Rod Zabala na taga Pampanga...
- Jul 2005
- 122
October 8th, 2009 10:47 AM #6mga bro, can I ask for rod zabala's contact number? pina-ship nyo sa manila? meron pa kaya syang available unit? Thanks.
October 8th, 2009 12:48 PM #7
yes they ship your orders. just make sure you tell him your problem first para malinaw at walang double shipping kasi iba ang starter ata para sa m/t at a/t na kotse. but i'll just pm you na lang the number. bawal ata i-post dito
- Jul 2005
- 122
October 17th, 2009 03:13 PM #9
paki post na rin ng number, sir. I'm sure marami ang interested, isa na ako doon. thanks
October 21st, 2009 11:34 AM #10
good am sa lahat, makisingit lang po, ganun din kasi naging problema sa hilander ko, after lumusung sa baha, nag cli-click lang pag start, pinatingin ko sa "along-the-road" auto-electrical shop, and sabi nila, pudpud na raw ang contact points ng solenoid. so, kumahoy sila ng contact points ng junk starter at linipat sa unit ko. okey naman for the first few days, ngayon, balik na naman ang problema. am planning to replace the solenoid, ang tanong ko po ay,may available ba na solenoid repair kit? kung buong starter assy ba ang papalitan ko, ay standard size ba ang mounting nito? mga magkano ba ang repair kit kung sakali? salamat po.
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
