Results 1 to 10 of 10
    Aug 2009
    nissan sentra, 1994 model,manual transmission, ayaw mag start
    sir newbie lang, ayaw magstart ng oto ko not unless itulak, pag insistart walang redondo, umiikot lang ang fan pag inistart, pinacheck ko sa mechanic sa shell, tinest yung baterya malakas naman karga, malaks naman mga lights at busina, sabi ng mechanic terminal lang daw ng battery, nastart ko pa pag alis ko sa shell pero kanina bago ko pumasok ayaw na naman mag start, napalitan na namin terminal ng battery, same prob pa din, kailangan itulak para magstart, ano kaya problem?
    thanks in advance
    Kung malakas ang battery . Pa check mo spark plug baka palitin na kaya mahirap mag start at iyong engine timing kung nasa ayos ayon sa specification ng makina.
    Sep 2009
    Don't forget the STARTER....check mo na din.
    Feb 2009
    Quote Originally Posted by lextripp View Post
    thanks in advance
    newbie,
    if the car starts when pushed, the engine must be doing okay. but if you try to normally start it and it does not crank, check the starting system. you already confirmed the battery is okay, now start with the ignition switch, then the clutch inhibitor switch, the starter relay, starter solenoid and finally the starter motor for worn out carbon brushes. this might be overwhelming to you. take this to a competent technician with that sequence of checks.
    jick
    thanks in advance
    I am thinking it might be the starter motor. Maybe you need new carbon brushes for it or something like that.
    Aug 2009
    mga sir salamat sa mga tips, kakadala ko lang sa mechanic yung carbon brush ang problem kaso wala ko mabilan ng same carbon brushes ng sa starter ko
    Feb 2009
    lextripp,
    you have a hitachi starter motor. any hitachi starter motor share the same brush holder assembly including that of chrysler jeep. it is easier to replace the brush and holder assembly than trying to solder the brushes to the holder plate. the liquid solder(while the solder is hot) tends to get wicked to the wires (capillary action) thus your brush wires will not flex because of the hardened solder.
    jick
    Oct 2009
    Start troubleshuuting from the Igniton switch, Dapat may B+ sa relay coil/terminal ng Solinoid switch. Kung walang clicking sound habang ini-istart, malamang ay walang B+. Kung may klick pero di umikot ang engine, the trouble is with the starter: maaring solinoid switch, carbon brush or rotor coil or stator coils... or just a lose connection on the starter B+.. yung malaking wire,,,
    Bro., nothing to do with the timing or Spark Plugs, umandar naman kasi... pag tulak...
    thanks in advance
    Oct 2008
    thanks in advance
    check the starter motor assy
    Aug 2009
    problem fixed, the carbon brush was replaced, now its working fine, thank you guys
nissan sentra 1994, ayaw mag start
