View Poll Results: What is the Longest Life of your Battery?
- Voters
- 88. You may not vote on this poll
less than 2 yrs
4 4.55% -
2 years
20 22.73% -
3 years
20 22.73% -
4 years
23 26.14% -
5 yrs and over
21 23.86%
Results 471 to 480 of 531
August 10th, 2022 12:10 PM #471
- 52,731
August 10th, 2022 12:15 PM #472
- 52,731
August 10th, 2022 12:17 PM #473yes and no.
if still under warranty, i'd bring it to the store for possible replacement.
the day after warranty expires, i'd tear out that cover, peep into the cells, and add water if necessary. baka makuha pa sa ganun.
some folks advocate this chemical or charger thingee, to revive dying batteries, but i have no experience with them.
August 10th, 2022 12:30 PM #474
- 52,731
August 10th, 2022 12:35 PM #475i'd read the etiketa, to see what they contain, po.
if it says pure distilled water, then it's probably safe for the battery.
nature spring... i think it's not distilled. i think it's purified (i.e., filtered) ground water.
if it does not speecifically say, "distilled water", i will assume that it is not.
August 10th, 2022 01:15 PM #477
BANNED BANNED BANNED
- Sep 2015
- 13,919
August 10th, 2022 02:24 PM #478tsikoteers,
you need to observe pag nasa supermarket. Si natures spring meron tatlo variant = mineral, distilled, high ph aka alkaline.
Si natures spring na pinakamura magbenta ng bottled water. Completo yan sa metro erod.
August 10th, 2022 08:07 PM #479
About 2 months beforw expected expiry dagdagan mo na ng distilled water.
Sent from my SM-A528B using Tsikot Forums mobile appFasten your seatbelt! Or else... Driven To Thrill!
August 10th, 2022 10:50 PM #480
Types of water:
1. Distilled - pure water from distillation
2. Purified - filtered thru several stages
3. Mineral - usually fresh unprocessed water from a spring source
4. Sparkling - carbonated
5. Greyp juice - straight from the gripo
high idle RPM at engine start
